Shut down WD before making any changes to these files, and make backups to any files before making any changes.
Attached is a file called “custom-main-screen”. Replace what Is in this file, with what is in your “wdisplayftp.reg” This file can be found Under wdisplay, data backup. Then click “Save”
Once complete, Double click on the “wdisplayftp.reg” file
If you plan on using the webcamimage, you may need to change the directory path in that file, Mine is set to D:\
Not sure, I will ever finish, it is a work in progress. The main screen is not published on my web site, so below is what I want to see (for now).
Again, thanks for getting me off to a great start!
Steve
you can get WD to export the registry settings (see under action, update windows registry entry now)
then double clicking on that .reg file will re import it
if you wanted to use someone elses template
Greetings!
Yes, below is the current screen capture, and attached to this message, are the settings, used in wdisplayftp.reg.
Word of caution, be sure to back up your files, before making the change.
in simple terms, all of it. i can not find the wdisplayftp file that is mentioned, nor do i understand how to edit it to get the new file loaded. computers are simple not me.
have looked at instruction posted by windy, to exsporting reg setting does not appear in my version of WD (the latest version).
also, the files postsed seem to be text files.
yes, understand how to do the update, but nothing changes, once i have done so.
when you say repalce what is in x file, with what is in y file, do you mean delete contebts of origional file and replace with data from your file? if so, this is what i have done, and nothing happens.
