cloudy
Author Topic: Twitter switching to OAuth means no more twitter updates by/from WD [RESOLVED]  (Read 1197 times)
Offline beun.net
  • Hilversum, The Netherlands
    • Meteo Hilversum
Quote
If you are like most Twitter users, you have used use a third-party Twitter application to read or send Tweets. As of August 31, Twitter applications will all use OAuth, an authentication method that lets you use apps without them storing your password.
More: http://blog.twitter.com/2010/08/twitter-applications-and-oauth.html
WD connects to Twitter via login/password. This no longer works, as one can read above.
I presume this is why my dedicated weather twitter account is no longer being updated by WD.
Will WD be updated to be able to connect to Twitter via OAuth?
« Last Edit: September 07, 2010, 06:22:39 PM by windy »
The Meteo Hilversum website: http://meteohilversum.nl
The Meteo Hilversum Twitter account: http://twitter.com/MeteoHilversum
Offline ALITTLEweird1
  • Mark
  • Snoqualmie,WA
    • Snoqualmie Weather
"Nature can do without man, but man cannot do without nature."
Davis VP2 + 1-Wire Solar + 1-wire Lightning + 1-Wire UV + Logitech Webcam
Offline JaxWeather
  • Bob
  • Global Moderator
  • WML Station: WD00007
  • Jacksonville, Fl. USA
    • JaxWeather.net
Re: Twitter switching to OAuth means no more twitter updates by/from WD
« Reply #2 on: September 02, 2010, 02:32:22 PM »
17th June 10.37P Build 37 .zip update: Added Twitter oauth support (you need to allow the new twitter to update, in the twitter setup (one time)
http://www.weather-display.com/history.php
OAuth has been supported since Jun 17...
Offline beun.net
    • Meteo Hilversum
« Reply #3 on: September 02, 2010, 02:35:34 PM »
Just when I was sure I had checked the entire forum before posting...  #-o
Thanks guys  :oops:
*updating*
*nothing to see here, move along please* :P
Offline DaculaWeather
  • Dacula Georgia
    • DaculaWeather.com
« Reply #4 on: September 02, 2010, 02:48:32 PM »
 :D
Steve Brueck
Davis Vantage Vue VWS, v14.01p25, Weather Display, Virtual VP, StartWatch
Offline EDWG
  • 10.37R B00 - XP-Pro
  • North Sea Island Wangerooge; Germany
    • Wangerooge Airport
« Reply #5 on: September 07, 2010, 01:54:41 PM »
Oh no,
.NET Framework v4.0 runs obviously not under Windows 2000 ..... so it's not possible to run the wdtwitter.exe ?!  :(
Online Weather Display
it was compiled with MS Visual Basic, and needs .NET 4
windows 7 is much better than windows 2000
Offline EDWG
all my weather data is on a W2K machine... a lot of work
Found an easier way: I'm currently "twitting" via a XP Prof wd-client
 :wink:
