cloudy
Author Topic: 2 WD's Starting (Now Sorted)  (Read 519 times)
Offline Geoff P
  • Nil Carborundum Illegitimi
  • Harwich, Essex, U.K
    • Harwich Weather
« on: September 02, 2010, 05:49:20 AM »
Hi  all,
Could anyone  give me an idea as to why when I reboot my pc I get two WD's starting at the same time, I have to close one of them and let the other run?
Got me baffled this one
Many thanks
Geoff
« Last Edit: September 03, 2010, 04:37:21 AM by Geoff P »
Offline Stronghurst
  • You Are Never Alone With a Schizoid
  • Stronghurst,IL USA
    • Burgus Computers
Re: 2 WD's Starting
« Reply #1 on: September 02, 2010, 08:14:40 PM »
The same thing is happing to me.
http://www.weather-watch.com/smf/index.php/topic,47136.0.html
As you can see I found out why.  I just need to know what entry needs to be removed.
Mark
http://www.burgus.org
Every day is a good day.  Just that some days are better than others.
Offline Geoff P
    • Harwich Weather
Re: 2 WD's Starting (Now Sorted)
« Reply #2 on: September 03, 2010, 04:41:43 AM »
Hi Mark,
Found my problem and cured it, in windows I went:- Start, Run, typed msconfig Enter, Start Menue, and found that there were two entries of WD both ticked to start at the same time on startup, I just unticked one of rhem, Saved and restarted the pc and everything was back to normal.??????????????
Offline Stronghurst
    • Burgus Computers
« Reply #3 on: September 03, 2010, 12:52:04 PM »
In my posting I showed where in the registry the double entries were.  But they had different starts to them .  One is "Delphi 3#Autostart" and the other is "Delphi 5#Autostart"  What is the correct one to delete?  They clearly are not the same.  And I have no idea what the number in front of it means.  Delphi is most likely the compiler that Brian uses.
Mark
