hello on Monday can give you more information on how to further configure the sensors and the station is now collecting evidence but no real data collected
not to take the temperature of the solar sensor to do
delete the ID of the sensor
off WD
open the file wdisplay.ini
find the line where you put the rom ID and remove it (the ID, not the line). Record and restart WD.,
OneWireViewer WD and can not operate at the same time, or one or the other but not both at once, stepped on the signals.
- You are using external power? I guess so, because the UV sensor needed. Eye that is stabilized and within the limits accepted by Hobby-Boards. And keep in mind that if you use it, there is a jumper on the solar sensor board must be set.
