hello
given temperature and humidity sensor
testing with UV Sensors and Humidity / Temperature
12V stabilized fed together by wire connector the central contant
are detected by onewirewiever
in WD are also detected, but the detector Tem / Hum sends no data.
remove the UV sensor core cable then if sent, I check in
WD / Solar Sensor / Setup
Solar Max tab etc. Time of Day. etc.
in raw current reading is raising the mv when disconnected from the UV and becomes fixed when I connect.
I do something wrong, you can give me some solution
thank you very much
emilio pla
