cloudy
Author Topic: Weather Display on iPhone/iPad via clientraw.txt  (Read 7188 times)
Offline southfreo
  • South Freo
  • South Fremantle, WA
    • South Fremantle Weather
« on: August 07, 2010, 02:04:54 AM »
Hi All,
Just a note that I added support to display clientraw.txt to a little weather app I've created called Sol Tiempo.
It's free and supports iPhone/iPad devices and allows new weather sources to be added/configured via an XML configuration file.
You can download it here :-
http://itunes.apple.com/au/app/sol-tiempo/id372732145?mt=8
Cheers
Kevin
Offline scudlly
  • ((Trev))
  • Geelong, Victoria ,Australia
    • Geelong Weather
Re: Weather Display on iPhone/iPad via clientraw.txt
« Reply #1 on: August 07, 2010, 01:02:58 PM »
Nice iphone app works well Thanks
Offline Peterjii
  • Seattle, WA
    • http://peterjii.homedns.org/weather/onlineweather.html
« Reply #2 on: August 07, 2010, 02:23:19 PM »
does it only display in Celcius? Can't find a setting to switch to Fahrenheit?
Online Weather Display
« Reply #3 on: August 07, 2010, 06:28:37 PM »
is this a an actual program that runs on an Iphone where you then select the clientraw.txt file location?
if so, good job
thats something I was looking at creating but did not progress very far :)
Offline stumpey
  • Sunbury on Thames UK
    • Sunbury Weather
« Reply #4 on: August 09, 2010, 06:57:35 PM »
Looks great on the iPad, is there a way to change the units of measure ie knots to mph etc
But otherwise a Nice looking app :)
Steve
Offline stewart45
  • Blue
  • Things are never as bad as you think they are
  • Cleveland UK
    • Newlands weather Station
« Reply #5 on: August 12, 2010, 08:28:59 AM »
Excellent app, it would be nice to be able to the units i.e. knots to mph or kph and temp, other than that nice work
Offline barrytmedia
  • Atlanta, GA
« Reply #6 on: August 15, 2010, 04:24:54 PM »
Well done!  Thanks!
Would love to see a way to chg units on the wdl profile.
Barryt
Offline Stuntman
  • Hemet, California USA
    • Hemet Weather
« Reply #7 on: October 28, 2010, 05:17:07 PM »
Very nice.. but agree that it needs to do some unit conversions for those of us not so fluent in the metric units..
Offline southfreo
  • South Freo
« Reply #8 on: October 30, 2010, 07:58:50 AM »
Sorry for the delay in replying, There is a new universal version of Sol Tiempo in review with Apple, should be available in a week (hopefully).
http://twitpic.com/325hjm
You can now view the Temp in Celcius or Farenheight, the graphs are still metric in this version, I'll fix that next release.
I'll update this post once it's available.
Cheers
Kevin
Offline Stuntman
    • Hemet Weather
« Reply #9 on: October 30, 2010, 03:43:22 PM »
Excellent?  What about the other units?  MPH, inHG?
Thanks!
Offline macsolve
« Reply #10 on: November 14, 2010, 08:44:58 PM »
Very nice!
Did you get m/s in there as well as unit for windspeed?
Offline southfreo
  • South Freo
« Reply #11 on: November 18, 2010, 01:40:24 AM »
The new version (2.1) is now available from the AppStore, you now have the option to display the main temp in Celcius/Farenheight. (It's a dynamic update, so wait 10 seconds for it to download).
The wind is still Knots, Graphs are Knots,Celcius,MM.
I'll fix the graph units next update, It's a bit more work on the QuotaXML engine which drives all this and needs to be tested in the other products it's used in.
Cheers
Kevin
http://www.southfreo.com
Offline n7xrd
  • Steve
  • Renton,Wa.
    • Renton,Wa. Weather
« Reply #12 on: November 20, 2010, 10:57:55 PM »
how do you change from Celcius/Farenheight?
Cheers
Kevin
Offline southfreo
  • South Freo
« Reply #13 on: November 21, 2010, 02:26:43 AM »
Sorry the update server crashed overnight and It's now back up.
Here's how to ensure you get the latest update which allows Temp in C/F.
Go into Sol Tiempo (If you running OS4+ you'll need to check for updates, do this by tapping the lower right hand button and clicking "App Settings")
Wait 10 seconds for the update to apply.
Now when you tap on the "i" for a weather display provider you should see "Temperature Unit" under URL for Clientraw.txt
If you find the temperature settings is not being remembered, restart Sol Tiempo (for OS4+ you double tap home to bring up the multi-tasking bar, then hold Sol-Tiempo until it wiggles, then tap "-")
The tap the SolTiempo icon again and it will restart.
Let me know any probs.
Cheers
Kevin
Offline n7xrd
  • Steve
  • Renton,Wa.
« Reply #14 on: November 21, 2010, 02:39:26 AM »
I can change it but it won't change on the Temp screen it keeps going back to Celcius #-o
Cheers
Kevin
