WU Graphs 1.8.0
WOW - thank you very much for a great script.
I have tried it - but have some problems getting it to work in standalone version:
http://www.silkeborg-vejret.dk/scripts/wug/wugraphs.php
I have theese settings:
$standAlone = true; // true = use wugraphs.php (also you may need set $loadJQuery and $incTabsStyle to true)
$includeMode = false; // true = included by PHP include function (eg: include(‘wugraphs.php’); )
Henrik
Well done Dave - good response and support!
I have just had an evening meal and a few wines, will try it out when I can, I’ll just have to make a new page… :wink:
G
Well I couldn’t sleep last night, and getting this going kept me up till 2:00am. Now it is 6:00am and time for work :sleepy1: One question: How can I get rid of the bad wind spike data from my last station? :?
You’d have to manually edit that spike data out on Wunderground.
Yes, but the month-max value unfortunately does not dissappear (in my case with temp-spikes) …
I implemented parts of these scripts on my site:
http://www.weerstationlangerak.nl/drupal/actueel
http://www.weerstationlangerak.nl/drupal/historie
Thanks for sharing!
Hi Henrik and thanks.
You need set $loadJQuery and $incTabsStyle to true (in new version is in default). :oops:
Hi drobbins,
thank for betatesting. :slight_smile: I released new version (0.7.6b). Validation problem could cause a wrong path to wz_toolitp (fixed).
BTW (to all): It is a “bad idea” change the copyright and other links. :frowning: Especially reference to wunderground must be included. Rest is propriety.
Hi again
Thanks for your reply. I have now changed to true in $loadJQuery and $incTabsStyle - but still some kind of problem:
Henrik
Sorry, my fault. #-o
You must change in file iframe-inc.php
$wugraphdir = '../wxwugraphs/'
to
$wugraphdir = './wxwugraphs/'
Will be fixed in new version (probably tomorrow).
Edit: I stuffed this fix into the current version (0.7.6b) … :slight_smile:
Hi drobbins,
i’ve installed your great script and passed the test here:http://www.meteocarmignano.it/wxwugraphs/WUG-test.php (I’ll make an italian language file soon!)
But this link not found…why? http://www.meteocarmignano.it/wxwugraphs.php
Thanks in advance for any help,
Alessandro
See the post above your’s ?
Hi Alessandro,
try download new version (strongly recomended) or modify your files as described at:
http://discourse.weather-watch.com/p/364531
and
http://discourse.weather-watch.com/p/364535
Looks Great, My Fly-out Menu just keeps getting bigger!!! :smiley:
jp
Hi again
That did the trick - now its working here:
I have now tried including into my excisting page - the wug folder are located in a subfolder (www.silkeborg-vejret.dk/scripts/wug/)
I have changed all paths in wugraphs.php and WUG-settings.php to full paths - but its not working:
www.silkeborg-vejret.dk/wugrafer.php
Have this in WUG-settings.php:
$standAlone = false;  // true = use wugraphs.php (also you may need set $loadJQuery and $incTabsStyle to true)
$includeMode = true; // true = included by PHP include function (eg: include('wugraphs.php'); )
Do you know if its possible to have the wug folder in a sub-folder? If yes - do you know which paths in which files needs to be modified?
Thanks for a great script.
Henrik
Hi RAD-X
Thank you very much for a great script.
http://www.huweather.com/wxwugraphs.php
Great job RAD-X :smiley:
Hi again Henrik,
  • [li] Some PHP functions do not work with website paths like “http://yourwebsite.com/dir/subdir/a.php”.
    Full paths like “/home/web/public/WWW/dir/subdir/a.php” are no problem.[/li]
  • You may use iframe method. Just put to your page wugrafer.php
    [li] Why not upload the scripts to the root directory?
    In my manual is written:
    “Copy directory” wxwugraphs “and file” wxwugraphs.php “the root of your website”
    There are reasons why. :)[/li]
This is a difficult task and I am not able to resolve it now. :frowning:
Very nice script! Thank you.
Can’t figure out why I keep getting header errors on all pages.
Set up for stand-alone but will be integrating into my own format.
I see others with same errors in this thread.
http://vermilionweather.com/wugraphs.php
Excellent script for a beta! =D>
Bug report - When viewing monthly or yearly precipitation (inches), the amount is shifted by one decimal place. Instead of .95 inches it is displaying 9.5 inches.
O.K. thanks :slight_smile: I fix it in new version (today or tomorrow).
This is a problem with cookies and PHP. I look at it.
