cloudy
Author Topic: WU Graphs 1.8.0  (Read 48879 times)
0 Members and 3 Guests are viewing this topic.
Offline ninux
Re: WU Graphs 1.8.0
« Reply #615 on: December 12, 2011, 07:30:39 AM »
Hi all
Could it be possible to add on tab Humidity the indor humidity with the outdor humidity like temperature (out and in) ?
Thank you
Ninux
Offline Torjan
  • vantage pro2 plus
  • Randaberg. Norway
    • Regnskvett verstasjon
Re: WU Graphs 1.8.0
« Reply #616 on: December 15, 2011, 03:21:01 PM »
Hi!
would it be possible to get baro to go lower than 980hpa, down to 950.
Have had such low values in the last days and these dint show on the graph.
Torjan
Offline georg
  • Denmark
    • Arloese
Re: WU Graphs 1.8.0
« Reply #617 on: December 16, 2011, 05:54:18 PM »
Same here, went through the bottom
georg
Offline RAD-X
  • Hovezi, Czech Republic
    • Pocasi Hovezi
Re: WU Graphs 1.8.0
« Reply #618 on: December 16, 2011, 11:26:51 PM »
Hi!
Torjan
georg
Yes, yes, of course.... guys from the north where it is low pressure .... :-D
Did you try to set a "Baro min/max and bands" in WU-Graphs configurator to Disabled?
Cheers,
Radek
« Last Edit: December 16, 2011, 11:34:40 PM by RAD-X »
Radek
Weather Hovezi | WU graphs | DONATE
Yes. My English is bad. But the effort is appreciated. :happy8:
Offline RAD-X
    • Pocasi Hovezi
Re: WU Graphs 1.8.0
« Reply #619 on: December 16, 2011, 11:36:18 PM »
Hi all
Thank you
Ninux
Added to features requests. Maybe it will be in next version.
Radek
Offline Torjan
  • vantage pro2 plus
  • Randaberg. Norway
Re: WU Graphs 1.8.0
« Reply #620 on: December 17, 2011, 08:35:38 AM »
Cheers,
Radek
Done! It worked well. Tanks!
Torjan
Offline AenG
  • Boskamp (Netherlands)
  • Win 7/Srvr 2008R2
  • MS IE 9.0
    • My homepage
Re: WU Graphs 1.8.0
« Reply #621 on: January 05, 2012, 09:15:26 PM »
Is it possible to open wu-graph in a popup window?
Not in a new browser tab, or the existing tab.
regards,
Geert
Offline duke666
  • Win 7/Srvr 2008R2
  • MS IE 9.0
Re: WU Graphs 1.8.0
« Reply #622 on: January 15, 2012, 08:57:59 PM »
I seem to be having a similar problem to a post a few back. I fill in the config page and then get the error below, pasted from the log, and also can not access wugraphs.php page, usually getting just a blank screen, not even a 404 or 406. I have edited the .htaccess file as suggested but with no effect.
Quote
[15-Jan-2012 17:45:21] PHP Parse error:  syntax error, unexpected T_ENCAPSED_AND_WHITESPACE, expecting T_STRING in /home/night239/public_html/wxwugraphs/settings.php on line 79
Duke
Offline duke666
  • Win 7/Srvr 2008R2
  • MS IE 9.0
Re: WU Graphs 1.8.0
« Reply #623 on: January 16, 2012, 01:33:42 PM »
I now have the configurator working by NOT selecting transparent and then it saves ok.
But now I have the following when opening wxwugraphs.php:
Quote
Warning: require_once(common.php) [function.require-once]: failed to open stream: No such file or directory in /home/night239/public_html/wxwugraphs.php on line 25
Fatal error: require_once() [function.require]: Failed opening required 'common.php' (include_path='.:/usr/lib/php:/usr/local/lib/php') in /home/night239/public_html/wxwugraphs.php on line 25
And when I try to open wugraphs.php I get a 406 but as mentioned above I have edited the .htaccess
Test page all seems good.
http://www.nightingaleweather.co.uk/wxwugraphs/WUG-test.php
Regards Duke
Offline RAD-X
  • Win Vista/Srvr 2008
  • Firefox 9.0.1
    • Pocasi Hovezi
Re: WU Graphs 1.8.0
« Reply #624 on: January 25, 2012, 04:48:41 PM »
Regards Duke
Hi Duke,
you graphs page at http://www.nightingaleweather.co.uk/wugraphs.php looks ok. Except Hour graps - probably bad path to clientrawhour.txt. Also you can disable hour graphs in configurator.php.
So do you have any actual problem with wugraphs?
Duke
I was unable to replicate your problem in configurator.php. I try to look at it later again. Or you can send me settings.php and configurator.php from wxwugraphs directory when this error appear.
Radek
Radek
Offline RAD-X
  • Firefox 9.0.1
    • Pocasi Hovezi
Re: WU Graphs 1.8.0
« Reply #625 on: January 25, 2012, 04:51:37 PM »
I don't know if it this good idea because many browsers blocks popup window. Why do you want this?
Radek
Offline RAD-X
  • Firefox 9.0.1
    • Pocasi Hovezi
Re: WU Graphs 1.8.0
« Reply #626 on: January 25, 2012, 04:59:47 PM »
About next new version of wugraphs.
Right before christmas I got two big jobs and this takes about 2-3 months to complete them. I'll try meanwhile create new version of wugraphs, but this isn't sure.
If somebody really need new version, for example because have many problems with actual version, please tell me this here or PM me or email me.
Radek
Offline duke666
  • Win 7/Srvr 2008R2
  • MS IE 9.0
Re: WU Graphs 1.8.0
« Reply #627 on: February 04, 2012, 04:31:37 PM »
Thanks for your reply Radek.
As you correctly say, I now have the graphs working as stand alone but, now I am having difficulty running them on another page with a simple:
Quote
<?php
include("wugraphs.php");
Page is here: http://www.nightingaleweather.co.uk/template101.php
Any ideas greatly appreciated.
Duke
Offline RAD-X
  • Firefox 9.0.1
    • Pocasi Hovezi
Re: WU Graphs 1.8.0
« Reply #628 on: February 04, 2012, 06:12:25 PM »
Duke
These errors is shown because you include WU-Graphs in CMS that already send output from PHP. If you don't have enough knowledge about PHP (for editing your cms), you have about three options how to solve this:
1.
You can try add into file wugraphs.php after line "<?php" this code on new line: "@ini_set('display_errors', 'off');" (without quotation marks)
This trick only hide this warnings, but some functions in WU-Graphs may be problematic. But I recomend to try, because this is easiest way.
2.
Don't use include function. Instead use in your template a html iframe element with link to wugraphs.php
This is 100% working way.
Example:
Code: [Select]
<iframe src="http://path.to.file/wugraphs.php" frameborder="0" width="100%" scrolling="no"></iframe>Note: You must add right path to wugraphs.php in a src attribute.
3.
Comment out or delete all problematic lines. But some functions in WU-Graphs may be problematic...
Radek
Offline duke666
  • Win 7/Srvr 2008R2
  • MS IE 9.0
Re: WU Graphs 1.8.0
« Reply #629 on: February 04, 2012, 09:49:50 PM »
Hi Radek,
Thanks for your quick reply. As you correctly point out, I've been learning about PHP for about 5 weeks so editing the CMS is probably beyond my skills at the moment. Perhaps you could point me in the right direction?
For now I have opted for option 3 to comment out the lines and all appears well at the moment.
Regards Duke
