cloudy
Author Topic: WU Graphs 1.8.0  (Read 48879 times)
Offline RAD-X
  • Hovezi, Czech Republic
    • Pocasi Hovezi
Re: Wunderground graphs 0.7.6 Beta
« Reply #30 on: July 27, 2010, 06:44:25 PM »
Hi RAD-X
I tested in firefox the graph is perfect.
 But Explorer will not go.
Maybe you can help?
http://www.huweather.com/wxwugraphs.php
Please be more specific.
The problem is the charset?
If so, maybe you used a bad php editor. My scripts are written in UTF-8. Try better text editor like eg: http://www.pspad.com/
To fix corruped (maybe) files you can try in PSPad:
- open php file in pspad
- ctr+a
- menu -> format -> click on UTF-8 (even though is checked) or you can try click to ISO 8859-2 especially for wxwugraphs.php and maybe others
- ctrl+s
- copy modified file to yourwebsite and test.
If not work, try another method of conversion of character sets.
Also your language file is corrupted - causing header error on my pages. Above-mentioned procedure solve header errors.
Also I found bug in WUG language switch (working on it).
« Last Edit: July 27, 2010, 06:52:48 PM by RAD-X »
Radek
Weather Hovezi | WU graphs | DONATE
Yes. My English is bad. But the effort is appreciated. :happy8:
Offline mfd38
  • Massachusetts
    • Medfield, MA Weather
« Reply #31 on: July 27, 2010, 06:56:05 PM »
Hi Rad-X,
I have followed the instructions you provided yet I must not be doing something properly. Would you mind taking a look here:
http://www.medfieldweather.com/wxwugraphs.php
Thank you,
Paul
Offline i_fiorentino
  • Alessandro Bardi
  • 160 mls Carmignano (Po), Tuscany, Italy
    • Meteocarmignano.it
« Reply #32 on: July 27, 2010, 07:10:11 PM »
Hi RAD-X,
i've installed the new version and it works ok here: http://www.meteocarmignano.it/wxwugraphs.php
Please, could you insert my site like "user" of this script?
As soon as possible i'll create an italian translation file....
Many thanks for your support,
Alessandro
Offline RAD-X
    • Pocasi Hovezi
« Reply #33 on: July 27, 2010, 07:14:12 PM »
Hi Rad-X,
Thank you,
Paul
Hi Paul, this file http://www.medfieldweather.com/wxwugraphs/js/jquery.cookie.js is missing on your website.
Thanks Alessesandro. Check link to your website. :)
« Last Edit: July 27, 2010, 07:53:53 PM by RAD-X »
Radek
Offline jpmorgan49
  • JP
  • Joliet, Il
    • jolietwx.com
« Reply #34 on: July 27, 2010, 07:15:51 PM »
Thanks jp.
You have a little hidden overflow in graphs. Try change Graphs Size in WUG-settings.php ($wugWidth and $wugHeight).
I think I have it, I just adjusted the width to '725'.  Does it look OK to you?  Thanks.
jp
http://www.jolietwx.com/wxwugraphs.php
Davis Vantage Pro2 Plus Wireless
WeatherLink Serial Datalogger
Iogear Serial to USB adapter
Acer Revo 3610 Nettop computer
Windows 7 64-bit
Offline mfd38
  • Massachusetts
« Reply #35 on: July 27, 2010, 07:19:52 PM »
Thanks Rad-X, but where do I place it - does it go on the wxwugraph.php file, if so where?
Sorry for all the questions, I appreciate your help.
Add: It does show here in the wxwugraphs.php:
if ($loadJQuery) {
echo '<script type="text/javascript" src="http://ajax.googleapis.com/ajax/libs/jquery/1.4.2/jquery.min.js"></script>';
echo '<script type="text/javascript" src="./wxwugraphs/js/jquery.cookie.js"></script>';
echo '<script type="text/javascript" src="./wxwugraphs/js/jq-core-widget-tabs.min.js"></script>';
« Last Edit: July 27, 2010, 07:22:04 PM by mfd38 »
Offline RAD-X
    • Pocasi Hovezi
« Reply #36 on: July 27, 2010, 07:42:08 PM »
Nope. Copy file "jquery.cookie.js" to "wxwugraphs/js/" directory on your website. :)
Maybe this file was not copied or is damaged.
jp
I don't know, but active area in your pages for this graphs is 639px, so try change $wugWidth value to 639 or something close to this value. 8)
Radek
Offline jpmorgan49
  • JP
  • Joliet, Il
    • jolietwx.com
« Reply #37 on: July 27, 2010, 07:53:57 PM »
I set it to 639 and it looks better.  "You the Man", thanks.
jp
Windows 7 64-bit
Offline mfd38
  • Massachusetts
« Reply #38 on: July 27, 2010, 07:54:09 PM »
Quote
The jquery.cookie.js file did exist in the wxwugraphs.js directory, I uploaded a new copy of it as you suggested but it has not made a difference.
Offline RAD-X
    • Pocasi Hovezi
« Reply #39 on: July 27, 2010, 08:16:06 PM »
O.K. In this case the problem is probably caused by something on the server. Maybe some caching or I don't know ...  :-k
The link http://www.medfieldweather.com/wxwugraphs/js/jquery.cookie.js must be functional, but I getting a "404 error".
Try rename the file "jqery.cookie.js" to "jqc.js" in yours website and in php scripts.
Add: this is "406 error" - my mistake. So server side problem/restriction. But I don't know how to solve it.
« Last Edit: July 27, 2010, 08:23:38 PM by RAD-X »
Radek
Offline mfd38
  • Massachusetts
« Reply #40 on: July 27, 2010, 08:28:20 PM »
Quote
Bingo! That did it  :D   http://www.medfieldweather.com/wxwugraphs.php
Thank you very much Radek.  Great script. I appreciate your patience and effort to help me out.
Paul
Edit: hmmm...did work for a few updates #-o
« Last Edit: July 27, 2010, 08:30:24 PM by mfd38 »
Offline RAD-X
    • Pocasi Hovezi
« Reply #41 on: July 27, 2010, 08:38:00 PM »
So, where was the problem?
Edit: I see... http://www.medfieldweather.com/wxwugraphs/js/jqc.js So server side filename restriction... :)
« Last Edit: July 27, 2010, 08:41:33 PM by RAD-X »
Radek
Offline jwwd
  • Silkeborg, Denmark (56:10:58 N-09:30:26 E) - Elevation 75,35 meters
    • Weather at Silkeborg, Denmark
« Reply #42 on: July 27, 2010, 08:43:07 PM »
Hi again Henrik,
  • Some PHP functions do not work with website paths like "http://yourwebsite.com/dir/subdir/a.php".
    Full paths like "/home/web/public/WWW/dir/subdir/a.php" are no problem.
  • You may use iframe method. Just put to your page wugrafer.php <iframe src="http://www.silkeborg-vejret.dk/scripts/wug/wugraphs.php" width="580" height="690" scrolling="no"></iframe>
  • Why not upload the scripts to the root directory?
    In my manual is written:
    "Copy directory" wxwugraphs "and file" wxwugraphs.php "the root of your website"
    There are reasons why. :)
This is a difficult task and I am not able to resolve it now.  :(
Thanks for your reply. Got it working by the <iframe> method. (www.silkeborg-vejret.dk/wugrafer.php)
Code: [Select]
[b]Why not upload the scripts to the root directory?[/b]I have all my scripts located in a subfolder, aswell as all my wx-data are located in another subfolder - in that way I got a "clean" root folder and I prefer that. I know it gives me a lot of troubles  :D
I have attached translationfiles in Danish - hope you can add them to your .zip.
Henrik
Offline mfd38
  • Massachusetts
« Reply #43 on: July 27, 2010, 08:43:21 PM »
Quote
Bingo! That did it     http://www.medfieldweather.com/wxwugraphs.php
But for some reason now it won't load - site says it is Not Acceptable and has a 404 error message.
 Could be restricted again?
« Last Edit: July 27, 2010, 08:53:09 PM by mfd38 »
  • Alessandro Bardi
« Reply #44 on: July 27, 2010, 08:50:07 PM »
Hi RAD-X,
here is the italian translation file for your great, great script.
Alessandro
