have you tried contacting wunderground?(since the data feed is via CWOP to wunderground, I take it)you can have WD update wunderground direct...
the problem might be that this new CWOP station has not yet been allowed to update to MADIS, or has been stopped from doing so, if it was, for some reason (data quality, who knows)have you asked Russ?
If I remember right, if you provide your CWOP ID in the Wunderground setup it will filter out the MADIS submission so that you don't see your data twice. Maybe that is it?- Jim
I have mine set up the way yours is because there's no reason for Wunderground to show the same data under two different IDs, the Wunderground ID and the CWOP/MADIS ID. Either way, if you're sending to CWOP it'll go through the MADIS system and get to where you want it to go.- Jim
On Wunderground just go find your PWS settings then it'll all become obvious. Hopefully you have your password to get in there.- Jim
Enter their CWOP ID in their Wunderground settings and they'll act the same.- Jim
