I use the Pro 9000 with 2 x 5m Active USB extending cables, I did try it with the cheaper Cat5e and
USB extenders but it did not provide enough power to run the webcam at a reasonable quality, it was
pixelated. As soon as i tried it with the Active USB cables its worked great ever since, but, Like
TokKiwi said, it does use about 50% processing power using the WD webcamcapture program, so
if you do have an alternative solution, i.e. the Network camera then go for it unless your using a
reasonable PC....
You can see a video of my webcam here
http://www.northantsweather.com/videolastday.wmvPlease excuse the squatter in the housing, IT will be evicted as soon as i send the Mrs up there
cause theres no chance i will be going near the darn creature
