cloudy
Author Topic: WM918 Connection issues in WD  (Read 2651 times)
Offline optrex
    • Springston Weather Station
« on: March 09, 2010, 06:08:02 PM »
I have a WM918 connected to Ubuntu 9.10 via a physical serial port.
The serial port works and I can run other equipment off it in Ubuntu without issue.
The WM918 connects using virtualbox and an XP client to both Cumulus and VWS and works fine with /dev/ttyS0 being directed to COM1 in the serial pass through.
The linux version of WD (10.37L) will not pick up the data stream from the WM918, with the exception of about a hour last night (it stopped working again after a save and exit). I got it working just by changing and swapping settings. Eventually it picked up from COM 1 (as it should)
The COM port is fine, it even picks up as connected using the 2500 option in WD, but for some reason WD is not responding. I have tried the other OS settings to see if that helps. I have tried releasing the COM port etc, without success. I can start virtualbox back up and everything will work fine again on other software. The WM918 console is mains powered.
I've read through a lot of other historical 918 threads and they all say its not WD, its the Linux setup. I think I've done enough to rule this out as the COM port works in other applications on the Ubuntu platform and the weather data comes through in other software. Would appreciate some help and suggestions please
Thanks in advance
NZ Weather - www.nzweather.net
Weather Station Finder - www.weatherstationfinder.com
Re: WM918 Connection issues in WD
« Reply #1 on: March 10, 2010, 01:35:00 AM »
Quote
so it does work,yes?
Offline optrex
« Reply #2 on: March 10, 2010, 01:39:24 AM »
it has worked, once yes. So there is hope ;)
« Reply #3 on: March 10, 2010, 02:28:07 AM »
then you just need to repeat the settings/serial properties, etc , you had when it was working
Offline optrex
« Reply #4 on: March 10, 2010, 03:00:23 AM »
Oh dear :(  I'm sorry but can't believe that's a serious reply to a support question.
Do you not think that given the detail that was put in the original post that I've tried that already?
I got it working just by changing and swapping settings. Eventually it picked up from COM 1 (as it should), but it stopped working again after a save and exit. To avoid any doubt I have tried a similar approach several times since but it has not been effective.
« Last Edit: March 10, 2010, 03:45:51 AM by optrex »
Offline BigOkie
  • Tulsa, OK
    • East Tulsa (Douglas)
« Reply #5 on: March 10, 2010, 03:39:24 AM »
Have you thought about changing permissions on the Com port via chmod?
Something possibly like chmod 766 /dev/ttyS0 (or whatever TTYSx your comport is)?
Offline optrex
« Reply #6 on: March 10, 2010, 03:45:30 AM »
Hi BigOkie,
Thanks for the reply. I have followed the instructions for udev on the ubuntu platform as listed in the wiki http://wiki.weather-watch.com/index.php/Linux_Weather_Display_Manual
I can confirm that the COM ports are 777 as is the WeatherD file.
Within WD in the WS2500 tab, I get the following:
Loaded all time records
Connecting com port
trying to open comport 1 8
Com port connected OK
« Last Edit: March 10, 2010, 03:47:25 AM by optrex »
Offline BigOkie
  • Tulsa, OK
« Reply #7 on: March 10, 2010, 03:52:59 AM »
Hi BigOkie,
Connecting com port
One other thing to keep in mind is that Brian is providing the Linux version free of charge, so he won't be able to update it as frequently as that which puts bread on his table.  I used the Linux version for about two years, but decided it was way too much of a hassle (would lock up about every day requiring a restart; I don't fault Brian for that, it's the nature of Linux when you're writing specifically for Windows).  I guess that the multiple flavors of Linux and versions of GTK/QT don't help Brian in his coding much.  I put XP SP3 on a machine and bit into my wallet for the Windows version and can say I'm glad I did.
I'm afraid other than the previous suggestion of the comport permissions that I can't be of much more help given that the only two stations I've ever owned are a Lacrosse 2310 and my current, Irox/Honeywell TE923W.
I hope you can get a resolution.
Offline optrex
« Reply #8 on: March 10, 2010, 04:04:10 AM »
OK, well many thanks for your help so far.
« Reply #9 on: March 10, 2010, 06:22:40 PM »
Quote
Oh dear Sad  I'm sorry but can't believe that's a serious reply to a support question.
I sure hope you are not here to cause trouble on this forum Optrex
it was working but is not now then that is likely to be a permissions issue after restarting WD (assuming WD is set to the correct station type)
I am seriously thinking of dropping the linux version due to attitudes (like it cant be a problem at my end (but there is so many different combinations of distros/settings/setups that its a nightmare to support (might work OK for me an others but not for other people) displayed on the linux section over the years, and instead concentrate on the Mac version, which has only the one OS flavour and same hardare
« Last Edit: March 10, 2010, 06:29:38 PM by windy »
« Reply #10 on: March 10, 2010, 07:14:20 PM »
for the record, just did a test here with my WM918 and the linux version
no problems, data works after going setup, save and exit, on the next restart, every time
(using a USB to serial)
so there is no problem to fix here for the WM918 station connection
Offline optrex
« Reply #11 on: March 10, 2010, 10:14:55 PM »
Thanks for the test Brian, out of interest what COM port is assigned to your USB to serial adapter?
« Last Edit: March 10, 2010, 10:18:43 PM by optrex »
« Reply #12 on: March 10, 2010, 10:41:35 PM »
I set it as it says to set in the com port setup if using USB
i.e
/dev/ttyUSB0
and using the default Distro built in USB to serial driver
Offline optrex
« Reply #13 on: March 10, 2010, 11:49:32 PM »
Yes I appreciate the use of that setting when using a USB to serial adapter, but as I understand that I dont need to enter /dev/ttyS0 in that field as I am using a physical COM port
What I am trying to ascertain is which COM port you selected during your test. If you are going through a USB to serial adapter, then you are not using COM1. I noticed in previous comments that people have been advised to get a USB to SERIAL and it has worked in many instances, but you shouldn't need to do that.
I am thinking along the lines of there being a communication error from within the WD programming when using COM1 with a WM918 that may not be apparent when using another COM port. I am thinking along these lines because:
1) WD detects COM1 as open when looking at the WS2500 settings, but does not receive data
2) The COM1 port works correctly across other hardware
3) The COM1 port works correctly across other software
4) All external testing programs and comand line returns indicate there are no issues, with comminications or permisisons on COM1
5) The combination of COM1 and WD is the only thing that does not work as intended (on my setup)
6) WD is detecting other equipment using other COMS (ie it picks up the data output from my LD250 on COM2)
As a test I will use the same physical port but assign it to /dev/ttyS2 in Ubuntu when I get home then select COM3 from within WD. If that works out OK, then I think that will give a clear indication as to where any issues lie.
Offline optrex
« Reply #14 on: March 11, 2010, 12:18:53 AM »
Ok, we're posting over each other, so I will wait and see how things go during my tests before commenting again on the technical aspects.
I am here for support of a product Brian, nothing else. I have invested a lot of my time to test and provide feedback to get your product working correctly for myself and maybe to the benefit of others. All I am after is detailed support related responses to my questions. If you felt you answered my support based post to the best of your ability, given the information supplied, then that's fine.
