cloudy
Author Topic: Power Measurment  (Read 6694 times)
Offline 2cvman
  • Cheers Peter
  • Near Monmouth. UK
Re: Power Measurment
« Reply #60 on: March 30, 2010, 06:40:40 PM »
Hi Guys,
Latest zip  Version on 30 March 2010 - 20:35:03
Now getting power counts :)
When showing,  Power Usage appears to be double?.... compared to my power meter.
Will let it run over night
Cheers
Peter
« Reply #61 on: March 30, 2010, 07:13:34 PM »
thats good you are getting the counts now 2cvman
you must not have got that update before for some reason
MichaelPT, i could set up a different counter for that....
Offline tbnilen
  • Kr.Sonnerup, Sjaelland, Denmark
    • Weather from (Roskilde) Denmark
« Reply #62 on: April 03, 2010, 09:03:04 AM »
it seems that the Power Measurement works fine, but it could be fine with a total KWh / day, ie (pulses * 1/Ration calibration factor).
when you have time to look at it ;-)
Happy Easter
Tommy
Offline MrNetworker
  • Shelly Park Weather, Auckland, New Zealand
  • Shelly Park, Howick, Auckland, New Zealand
« Reply #63 on: April 04, 2010, 11:43:11 AM »
Happy Easter
Tommy
Sorry this is just a repeat of my previous post.
I'm still getting spikes which would be nice to loose.
Kw /hour and Kw /day would also be a nice feature.
Option to choose how often counter is read  1-5 mins.
When you get time Brian and would be much appreciated  :D
Cheers Daniel
« Reply #64 on: May 31, 2010, 05:18:50 PM »
I discovered I was applying the time taken for the count across the minute wrong
the latest .zip update fixes the spikes in the readings on the plot :)
Offline Bthree
  • Victoria Australia
« Reply #65 on: April 07, 2011, 06:07:15 AM »
Been looking for a method of displaying the power output of my PV solar array inverter
The PVE-1200 inverter has a KWH digital meter that outputs 1 pulse per watt
Connected up a counter and ran a trial of WD ... and it works... looks promising
Unfortunately the watts output in the setup screen is 60 times greater than the actual output while the scale of the graph in the wind direction box looks OK, also the minutes to average reading will only save as one (1)
Can you have a look please Windy.
« Reply #66 on: April 07, 2011, 08:39:30 AM »
not really sure what you are trying to explain
can you provide more info/screen shots, etc, maybe?
Offline Bthree
« Reply #67 on: April 07, 2011, 09:07:32 AM »
Attached is the capture of my present setup screen
"Power usage"   current usage is 0.0w (because its dark and this is the output of my PV array
but when active the displayed figure is 60 times higher than the actual output of the PV array
Also I cannot change the "Minutes to average reading" cannot be changed from one (1)  no biggie really
Hope this helps, if not I will try tomorrow when the sun is up
Offline Bthree
« Reply #68 on: April 07, 2011, 09:28:45 AM »
Added possibly a better overall view
The Ratio calibration factor should be 1000 but I decreased that to 250 to get better scaling on the wind direction graph
