cloudy
Author Topic: Urgent problems with WD  (Read 1922 times)
Offline weatherc
  • Salo, Finland
    • Weatherstation Salo,FI
Re: Urgent problems with WD
« Reply #15 on: March 07, 2010, 01:02:07 PM »
No, i haven't changed VVP. Will do a test with a older version of WD, just to see if its have any difference.
EDIT: Testing with VVP + 10.37O Build 02 now and so far seems good. Do someone have a earlier version of 10.37P to test with?
Henkka
« Last Edit: March 07, 2010, 01:20:39 PM by weatherc »
Offline jwwd
  • Silkeborg, Denmark (56:10:58 N-09:30:26 E) - Elevation 75,35 meters
    • Weather at Silkeborg, Denmark
« Reply #16 on: March 07, 2010, 02:11:29 PM »
Henkka
Hi Henkka
I sent you e-mail - with link to WD full version 10.37P build 14 from December 6 2009 at 06:35
Henrik
« Reply #17 on: March 07, 2010, 05:38:28 PM »
one thing that changed in WD is that I now check the barometer value
if that goes out of range, then WD will ignore the data
I know there was a firmware update to correct problems with the barometer on the console going out of range when the indoor temperature got high
« Last Edit: March 07, 2010, 05:41:38 PM by windy »
Offline weatherc
  • Salo, Finland
« Reply #18 on: March 07, 2010, 05:53:24 PM »
Thanks to jwwd i have now a few older versions of WD to test with (at the moment on 32bit XP). The two what i have tested are 10.37P b 14 and 10.37P b20. I have also b16 here but not tested it yet.
b14 works fine, 2000+ packets without problems. b20 have so far only few hundreds packets but one thing i noted:
In b14 the WD's clock works smoothly and fine, but in b20 it every now and then takes 2-3 seconds jumps instead of the smooth 1 second-jumps, also outside of the top-of-the-minute. There are almost more of the odd jumps than 1 second-jumps now when looking at it. In b14 it don't do it.
I have that force baro every minute unticked.
Henkka
« Reply #19 on: March 07, 2010, 06:27:35 PM »
the new 3D gauges take a bit more CPU than the old ones
what speed PC?
I could undo that barometer check as a special version for you to test
Offline weatherc
  • Salo, Finland
« Reply #20 on: March 07, 2010, 08:31:35 PM »
Its a Dual Core Intel @ 2.6 Ghz + 2 Gb RAM.
Quote
Ok, lets do it and see :)
Henkka
Offline weatherc
  • Salo, Finland
« Reply #22 on: March 07, 2010, 10:03:53 PM »
thanks. Installed it. At least beginning seems fine, 200 packets get without problems, the clock is still a bit jumping but maybe its just a cosmetic thing, bedtime now so will let it run to tomorrow and see how it goes. :)
Henkka
Offline weatherc
  • Salo, Finland
« Reply #23 on: March 08, 2010, 12:26:20 PM »
Brian,
Nope, did not help. The special b22 stopped after 330 packets too, tryed 2 times and both times it stopped almost at at same place.
But b20 seems to work, with no changed settings or similiar, just a clean downgrade.
best regs
henkka
Offline weatherc
  • Salo, Finland
« Reply #24 on: March 08, 2010, 07:09:07 PM »
Hi again Brian,
Got b21 to test with and it didn't worked either so as result:
- 10.37P b20 (and earlier) works
- 10.37P b21 (and newer) do not work, they stop after x packets
best regs
henkka
Offline Chas
  • Dayton, MD USA
    • Dayton, MD Weather
« Reply #25 on: March 08, 2010, 09:49:14 PM »
I am also running Win 7 64-bit with VVP and had the exact same issues as you. I solved it, but you may not like my solution. I could not get the free 64 bit driver to work with WD. I had to purchase the VSPE program from Enterlogic.com. My installation has been rock solid ever since.
Offline niko
  • syzygy
  • Global Moderator
  • Northern California, U.S.A.
« Reply #26 on: March 08, 2010, 09:54:58 PM »
Quote:
Thanks to Microsoft Corporation policy, we need to pay $499 every year for the digital signature to make VSPE work on this platform [64 bit]
That's why you need to order 64 bit VSPE license.
It's price is $24.95.
 :roll:
But $25 really isn't a lot for something that works well  :D
« Reply #27 on: March 11, 2010, 02:56:52 AM »
I might have found something
try build 24 .zip update
Offline weatherc
  • Salo, Finland
« Reply #28 on: March 12, 2010, 01:04:56 PM »
Hi Brian!
The new zip seems to work, 45000+ packets and growing.
Thanks Brian!
cheers
henkka
Offline weatherc
  • Salo, Finland
« Reply #29 on: March 15, 2010, 06:02:06 PM »
After 240000 packets build 24 flatlined.   :(
So i installed b20 again to see if its gets better.
Henkka
