Hi all,
Needing ideas now as i'm totally out of them now....Atm are my sites updates down what they have been for some days now...Last night i *tought* i finally got WD to work, but nope, resulted up with hours of flatline before i noted it.
My WD don't want to play anymore, thats it.
Atm running on a fresh win7 64-bit but tested with a fresh xp too with same results.
Serial logger in use.
The setup is VVP + com0com-driver set to push data to ports 6/16,7/17 and 8/18.
WeatherLink on port 7 and Cumulus on port 8 works both just fine.
With a fresh install of a 2WD set to port 6 starts fine but after few minutes it stops and don't want to get any data anymore. Reboot of the box don't bring any help, same thing there.
That box in WD's viewtab what shows rawdata says com-port connected ok. Also in VVP in "Last Heard"-box resets the counters but in "Last sent"-box not.
Specs of the box:
Dual-Core CPU E5300 @ 2.60GHz
2 Gb RAM
All ideas more than welcome
Henkka
