Any of the UK members using a BT Hub.
If so, have you success with access between pcs.
Have issues trying to set up intranet?
Peter
Peter, from memory I set up wireless network on my daughters Homehub - help on Homehub here http://www.frequencycast.co.uk/homehub.html and used VNC which needs port forwarding to access her laptop - details of port forwarding here http://portforward.com/english/routers/port_forwarding/BT/BTHomeHub/Echolink.htm. If you only need network access I dont think you need port forwarding, but I wanted to be able to run & change programs on her laptop from mine.
Bob
Bob,
Thanks for the pointer, have looked various sites, it seems the BT hub are NOT the easiest.
Will try out
Peter
