Hi all,
I got my WMR-100N a couple of yeas ago. Pretty soon I also noticed the the instability in the signal. Back then I searched a lot for a solution but did not find any good info other than I was not alone. I also made sure to place the sensors so their battery did not get in the way of the radio signal, still there were problems.
A couple of days ago I thought I take a new search about the antenna problem which I also guessed the root of the problem. It led me here. Thanks epigenes for the assembly pictures. It helped a lot.
Now to the point. Although I am not an antenna expert. To my best knowledge an antenna is not going to work its best when bent like it is in the WMR-100. So i Simply took apart my WMR-100N and straightened the top antenna like in the pictures. Made a small groove to lead the antenna straight out the top of the case and still being able to close it snugly.
This seems to have made all the difference for me. Now it seems to find all the remote sensors fast and secure. Where as it often missed some sensors before or was soon to drop sensors connection.
This mod might not be enough for all out there but it seems to make a big difference and that was all I needed. Plus I did not need to solder anything or have an extra antenna attached via a cable. Although the now protruding antenna probably is a little fragile it still looks better than a "big" hole in the back if one does not need it.
