Success. I soldered a short piece of small coax to the unit with a bnc connector on the end. I hooked up a magnet mount antenna on it with about 15 feet of cable and a mobile antenna cut to the 433 frequency. I have the console in a spot where it worked ok until i plugged in the usb cable, then it lost the sensors. I could unplug the usb and it would work again. I dont know if moving the antenna away from the console or the shielded cable but plugging the usb in and out now makes no difference, might even be better signal strength. Now i can put a antenna outside that sees all the sensors and have the unit updating the pc everytime. It is working like it should have in the first place. mabe os should have put an external antenna on this unit. I have a remote temp/humidity sensor in a solar shield in a part of the yard that it was not seeing very well, but no problem with the mod. antenna hookup. I just set the antenna down on the coffee table in the middle of the living room and no special placement, works great. It looks like it is worth the effort to modify it. Will report later when i get a better antenna outside in a good location.
