Customs Sceen Background Image resize
Hello all,
I did setup different customsscreen.gif before.
But now, after a new install.
I upload my background image, resize the window to the background image size, all looks fine.
save all and to a upload or wait for a automatic upload.
when the customs gif is generated, the background image been strech bigger then before.
going back in the customs screen setup and i can see, the background image is bigger then before.
reload the background image, all is fine, till it generates a customsscreen again.
my feeling is, that some settings are not changing, but in the WDISPLAYini i can not find any setting, what i could change.
could be the image size is stored in the xp windows register?
thanks for some advise.
which version/build of WD?
10.37R Build81
Best regards
I think you will find I have fixed that bug with the latest version
(or versions earlier before build 81 were OK too)
Yep Brian,
the problem been on new version, that full install does not go on window XP.
i overright my old installation with the new one, not the with the install file.
thanks
you can install the new version on XP
(there are other threads about this)
install build 81
then just use the .zip update of the latest version
