cloudy
Author Topic: WD Mac Intel - New Install and Upgrade Info  (Read 10626 times)
Re: WD Mac Intel - New Install and Upgrade Info
« Reply #45 on: May 21, 2011, 04:34:27 AM »
so if no one is going to move past build 77 I dont think there is much point in supporting and offering it any longer
(especially as there is so few users left with the Mac version anyway)
Offline mfd38
  • Massachusetts
    • Medfield, MA Weather
« Reply #46 on: May 21, 2011, 10:49:13 AM »
I am currently testing build 80, since my last post as I stated I would do. I will give you an update when I have something to report, on a different thread as this thread is reserved for another purpose.
I think there is some confusion on the status of the last build which would explain why users have not moved forward with it. The only thread about it ( http://www.weather-watch.com/smf/index.php/topic,51013.msg410899.html#msg410899 ) was left dangling out there with no follow up from you, and the original poster went back to build 77 without stating why, so users didn't know where to go with it. Let's give it some time Brian before you abandon the mac version. Thanks,
Paul
« Last Edit: May 21, 2011, 11:30:15 AM by mfd38 »
Offline Blueruck
  • Colorado - USA
    • Vist my station
« Reply #47 on: May 21, 2011, 12:23:49 PM »
Brian, I will gladly use and test new versions for the MAC.
I had also read the thread on 80 and saw it dangling / open to if it was stable or not.  I know many times it is the user machine instead of WD that causes the issues.
I thought I read that you were having a problem with your mini, I would be willing to send $100 USD via paypal to help you out with your mini issues.  I'm a MAC convert and once I have WD on the MAC my home will be rid of Windows :).
Offline weathertwp
  • Madison Twp, Pa. USA
    • The Farmstead  2dogs2
« Reply #48 on: May 22, 2011, 04:59:34 AM »
Personally I will NEVER go back to a Microsoft / windows computer, even if they get all of their problems solved in my life !   ( Microsoft will never rid itself of bugs, malware, or viruses  )
Research-aholic by Nature ..
« Reply #49 on: May 22, 2011, 07:25:06 PM »
I use W7
works great
better than MacOS and my Mac
Offline weathertwp
« Reply #50 on: May 25, 2011, 07:23:58 PM »
I deal with every type of system where I work, from old dos 3.1 to W7,  3 flavors of Unix, Linux, Mac's etc etc ..  Personally I think anything with a unix kernel is more stable then
anything Microsoft will ever produce.   True there is more s/w for Microsoft platform, but it is usually buggy
Offline Norwegian Wood
    • Gunnarbu - Venabygdsfjell - Norway
« Reply #51 on: June 02, 2011, 06:07:06 PM »
I am at the newest build, 81 it says even dough it says 82 on the download page. No problems as I know, I use WD only to upload the necessary files for WDL to work.
Davis Vantage Pro2 with FARS and heated rain gauge
Axis P1346-E and 207MW
Meteohub - ALIX 3D2
« Reply #52 on: June 02, 2011, 06:09:57 PM »
I have fixed the build 82 not being available
have you fixed the problem you had before though or is it no longer a problem?
« Reply #53 on: June 02, 2011, 06:19:05 PM »
my problem with several instances of WD starting up over time is still there, but I control it by restarting my mac automatically every morning. I have given up finding out why WD starts over and over again. But it works fine, 100% availability and 100-200 users visiting my weather webpage every day.
Meteohub - ALIX 3D2
Offline heldo
    • mhelding
  • Mac OS X 10.7.2
  • Safari 5.1.2
« Reply #54 on: February 01, 2012, 09:58:37 AM »
Hi All
Running a MacBook Air with version 10.7.2. I am in the process of moving from and PC to the MAC and would like to install WD on it. Ive had a look through the download/install instruction and even after following them i get an error with the zip file (it is unstuffed correctly) the text in the crash reporting indicates that it is in fact a crash.
Any ideas on how can install this software?
M
  • Win 7/Srvr 2008R2
  • Firefox 9.0.1
« Reply #55 on: February 06, 2012, 11:30:10 PM »
HI
I missed this post
make sure to first install the full install version, and follow the instructions in the installer, and also install the library files
then the .zip update
Offline FotoCreatives
  • Professional Photographer
    • fotocreatives
  • Mac OS X 10.7
  • Firefox 10.0
    • FotoCreatives
« Reply #56 on: February 09, 2012, 03:33:14 PM »
After 2 days of trying installing the Weather Display for Mac (and reading this forum for solutions) with no successful results, I've decided to ask for help! HELP!!!!!
I recently own a Davis Vantage pro 2 (with the extra UV- and Solar sensors and has also the extra fan installed). I want to use the WD software on my iMac with OSX Lion (version 10.7.3). I did everything by the book and how it's explained on the forum but when I start the WD I only see the startup screen and it hangs...the rainbow-colored ball keeps spinning forever. Only with force-quit I can quit the program. The program seems to respond weirdly and sometimes I can reach the setup but I never saves my settings and again I have to use force-quit.
Offline Coyote
  • Mission Texas
  • Mac OS X 10.7
  • Firefox 9.0.1
    • Candasolar.com
« Reply #57 on: February 09, 2012, 03:46:51 PM »
Go to your Lion/Library/ApplicationSupport/ create a folder called wdisplay and make sure the folder permissions are read and write The mac install doesn't create the wdisplay folder in Lion
Coyote
    • fotocreatives
  • Mac OS X 10.7
  • Firefox 10.0
    • FotoCreatives
« Reply #58 on: February 09, 2012, 04:46:53 PM »
BIG THANK YOU Coyote!!  :D :D :D That helped a lot! I wish I could buy you a beer  :wink:
Now the program seems to respond and I can spent time to discover how to receive data from my Vantage Pro 2 into WD!
Cheers,
Frank
Offline don0344
  • Traveling and exploring in the Southwest U.S.
  • Southwestern U.S.
  • Mac OS X 10.7.3
  • Safari 5.1.3
    • RoadRunner
« Reply #59 on: February 09, 2012, 11:46:09 PM »
Coyote...
Thanks, Coyote. I owe you a beer, too.
