cloudy
Author Topic: WD Mac Intel - New Install and Upgrade Info  (Read 10626 times)
Offline jmar
  • Halifax, Canada
    • HRM Weather
« on: February 02, 2010, 02:33:40 AM »
Note: this thread is for install upgrade info and comments. If you need assistance with your setup, please post a new thread to the forum with your request. Thanks.
New Drag to install instructions for Intel Macs
The new design of Weather Display Mac now makes it possible to drag/install the application like any modern Mac program.
These instructions apply to Weather Display Mac version 10.37L build 44 and above, Mac Os X 10.4 (Tiger), 10.5 (Leopard) and 10.6 (Snow Leopard)
Please read the attached Read Me file for more info.
ALL USERS - A default printer should be selected in your System preferences as some usb drivers from various weather station vendors have been seen to incorrectly attempt connections to unassigned ports (sometimes connected user's printers instead of the station) causing issues for the app on startup.
New User and Full Installations
If your station requires a driver to be installed, you will need to obtain it from the station's manufacturer. Example - for the Davis USB stations, download and install the Silicon Labs Intel Mac USB Driver, from the Davis Support page.
Basically, for a new installation all you have to do now is open the Disk Image that is downloaded (full install) and opens in a window on your desktop.
Then:
1. Drag the WeatherD application icon to the Application folder shortcut on the left in that window.
2. Double click on the Resources Installer in the lower right portion of the window and follow the instructions in the installer. WMR100/200 Users, Irox users, and LabJack users, you will also need to select the extension in the installer that will talk to your station via usb in addition to the "New Install Libraries - All Stations" in the selection screen. See the Read Me file for instructions.
You will be asked to enter your administrator password, and a restart will be required.
3. After the restart, open your Applications folder and double click the WeatherD icon to start the application and begin your setup. You will get a warning from the operating system that the app was downoaded and prompting you to proceed the first time you open the application. This is normal so click ok.
Welcome to Weather Display Mac :)
Upgrading Weather Display
(Assuming you have installed WD Mac before and it's icon resides in your Applications folder)
Download the latest Application Update from the downloads page.
Quit Weather Display until after the upgrade is complete.
If it is in a Disk Image that opens a window on your desktop, drag the file to the Applications Folder shortcut to the left, replacing your old WeatherD icon as you are asked by the system.
Eject the Disk Image, which will be viewable either on your desktop or in a finder window, by dragging it to the trash or clicking on the arrow beside it's icon. The WeatherDisplay.Dmg file you downloaded will be in your downloads folder which can be mounted later should you wish to access it again or back it up although not necessary. No need to install from the Resources installer unless there is a library update and it is posted.
If it is in a zip file, unzip the file you downloaded and drag the WeatherD icon to your Applications folder, replacing the old icon when asked.
Things that are different now:  :lol:
Weather Display, the application and all its resource files, executables and crons, is now entirely contained within the WeatherD application icon, conforming to Apple's guidelines for Application Bundles. A very good thing that will make upgrading the program a breeze from now on, and eliminating the need for installers for new builds to the application. There will no longer be any need to open the application's bundle to replace the program's executables as the complete bundle (the WeatherD icon) will be distributed with every new build, so you will get everything in the app (crons, executables, etc) updated on each build with no more confusion regarding where and how to place each item.
The folder /Applications/wdisplay is now obsolete as of 10.37L build 44 . If you prefer to keep the WeatherD icon in that folder make sure you do not have multiple copies of that icon on your system. However, all of the crons and other files in that folder can be safely deleted. Assess whether any of the files are data files, as they are now kept (and have been since January of 2009) in the Application Support/wdisplay folder. If you decide to delete that folder you should see only a single WeatherD icon in the Applications folder like any other Mac application, with all data being stored safely in the Application Support folder as designed.
No more permissions scripts required to run after upgrading. Now the permissions are set in the application bundle by our fearless developer, so those scripts (although resident in the bundle for now) will no longer be necessary.
This redesign from Windy's perspective has been a huge undertaking, and demonstrates his commitment to the Mac community as he continues to migrate even more features from the Windows and Linux versions to the already robust and stable Mac version. Now the structure of the application is much more user friendly regarding installation, and improvements to the application can be used by all as they are released without waiting for installers to be prepared. Also the program is completely self contained, which also makes it fully portable as it will now run from anywhere it is moved on the user's Mac.
Many thanks Windy for the hard work you have put into this new install and upgrade process.
jmar
« Last Edit: March 22, 2010, 10:39:52 PM by jmar »
iMac, 2 x Mac Mini, Mac OS X 10.6.7, Indigo integration, Web - WDL, Saratoga templates, Lightbox
Offline mfd38
  • Massachusetts
    • Medfield, MA Weather
Re: WD Mac Intel - New Install and Upgrade Info
« Reply #1 on: February 02, 2010, 01:16:49 PM »
Congratulations to Windy, and Jmar for making the mac version of Weather Display what it is today.
I just installed build 44, the full install after first deleting the WeatherD.app build 43, and it worked like a charm. Installation and start up is unbelievably fast, no hesitation and little effort needed by the user. Naturally a brand new, never used before installation will take longer as you need to configure everything, but for upgrades it is extremely quick!
Thank you Windy, Thank You Jmar for all your hard work to make Weather Display such a powerful mac application.
Paul
Offline casper
  • www.meteodelft.nl
  • Delft-The Netherlands
    • MeteoDelft
« Reply #2 on: February 04, 2010, 12:38:33 PM »
Finally a clean install. Though I got used to the installation procedure this is definitely much better.
Thanks!
David Vantage Pro2 Plus
2x Vantage Pro Console (1 with logger)
solar+uv sensor
heated raingauge
running on MacMini (late 2009 / 10.7.3 Lion)
wd+wdl
http://www.meteodelft.nl
« Reply #3 on: February 04, 2010, 04:52:11 PM »
one thing to note, if you were using the original versions, the settings and data /logfiles were stored in the application bundle, in the contents/macos folder
make sure to move those to
/Library/Application Support/wdisplay/
before using the new application bundle
Offline nwikner
« Reply #4 on: March 20, 2010, 01:46:32 AM »
Here's a nubie question.  How do I tell what version I'm running?  If I do a Get Info on the application Icon in the Finder, it says version 0.1(!).  The creator date is Wednesday, April 29, 2009 5:31 PM, the Modified date is Tuesday, June 16, 2009 3:37 PM.  The WeatherD menu does not have an "About WeatherD" menu item, from which I could find this info.  I don't know where else to look.
« Reply #5 on: March 20, 2010, 01:48:39 AM »
when you run WD, see under help, about
also the version is shown as it starts up
also you can check the modified date of the WeatherD file in the application bundle, contents, Macos folder
Offline nwikner
« Reply #6 on: March 20, 2010, 03:53:44 PM »
Ah... There is no "Help" menu, but there is an "About" menubar item.  Clicking on that does not actually bring down a menu, but instead acts like a button and opens a window with with the information I want.  In almost every Mac program the "About <program name>" menuitem is the first one in the <program name> menu.  I note one other mis-feature (not really a bug, but odd behavior): each click on the "About"  menubar item results in the opening of another instance of the same static window.
« Reply #7 on: March 20, 2010, 05:45:42 PM »
sorry, it was just an about menu on its own
Quote
as long as the info is shown then I do not see what the problem is?
also make sure to close that window before clicking on the about menu again
(not sure why anyone would click on it again after not closing the window just opened and viewed?)
Offline don0344
  • Traveling and exploring in the Southwest U.S.
  • Southwestern U.S.
    • RoadRunner
« Reply #8 on: November 23, 2010, 05:13:38 AM »
I am running a MacbookPro Intel with OS X 10.6.5. My weather station is a Davis Vantage Vue with data logger. The WD Web site says it supports the Vantage Vue but when setting up I do not see the Vantage Vue listed in the "Station Type" panel. If I choose Davis Vantage Pro there is no communication between the two even though I have tried using both the tty.SLAB_USBtoUART comm port and the tty.SerialPort.
How should I set up my system?
Offline mfd38
  • Massachusetts
« Reply #9 on: November 23, 2010, 04:39:11 PM »
Hi don0344,
Check out this post here http://www.weather-watch.com/smf/index.php/topic,47707.msg386772.html#msg386772 , maybe you can reach out to Dafuser and see if he can get you going.
Paul
« Reply #10 on: November 23, 2010, 05:02:11 PM »
the Vue uses the same data logger as the VP
so as far as software goes, there is no difference between the VP and the Vuw
the latest .zip Mac update does now though say Vp/Vue in the weather station type setup
you will need to select the
tty.SLAB_USBtoUART
driver
and also make sure to select the default baud rate
then restart WD
does the data received light then flash?
Offline don0344
  • Southwestern U.S.
    • RoadRunner
« Reply #11 on: December 05, 2010, 10:17:24 PM »
Where do I find a .zip Mac update? The only files I see are .app files.
« Reply #12 on: December 05, 2010, 10:26:17 PM »
its right there on the download page
http://www.weather-display.com/files.php
Offline don0344
  • Southwestern U.S.
    • RoadRunner
« Reply #13 on: December 06, 2010, 01:38:08 AM »
OK, maybe it's me and I'm missing something obvious. Some time ago I downloaded the "Full Install," which is a .dmg file, and have never been able to get it to work on my Intel Macbook Pro running OS X 16.6.5. I have downloaded the "Weather Display Intel Mac Latest Application  v10.37L Build 67" which is also a .dmg file that opens immediately to "WeatherD.app" There is no zip folder in this download. One of the replies that I received to my post said "the latest .zip Mac update does now though say Vp/Vue in the weather station type setup". The versions of WeatherD that I have downloaded do not include the VantageVue in the set up page. That would not be a problem at all if I could get WeatherD to run on my Mac. Davis' WeatherLink program runs fine on my Mac with the same operating system and hardware configuration with which I am trying to run WeatherD. Some time ago I was able to run WeatherD on a PC with the same Davis VantageVue weather station configuration running Windows XP but I no longer want to use the PC. I want to use the Mac for everything I do and so far have been successful except for WeatherD. I would appreciate any help that would allow me to do this.
Don
« Reply #14 on: December 06, 2010, 02:21:37 AM »
when I mouse over the link for the Mac .zip version
from this page
its a .zip file and not a .dmg file
make sure you are actually clicking on the .zip Mac download
(unzip to where you have the Application bundle installed to from the full install)
note that as far as the Vue goes, the davis VP settings works (its the same data logger)
just make sure to have the davis Mac USB driver installed  which should then show up in the com port setup
there are others who are using the mac version with a Vue successfully (e.g NorcalDan)
