cloudy
Author Topic: Weather Display Live for the iPhone and Android  (Read 58346 times)
Offline drobbins
  • Kentucky, USA
    • Cave Country Weather
Re: Weather Display Live for the iPhone and Android
« Reply #285 on: August 08, 2010, 10:26:57 PM »
I agree. I use FF and was getting a scroll bar with the forecast iframe. The frame is the correct size on my daughters itouch.
Offline drobbins
  • Kentucky, USA
« Reply #286 on: August 10, 2010, 11:05:42 PM »
Is there any way to add pages linked from the home page?
Offline atsio
  • Weather at Thessaloniki - Northern Greece.
  • Macedonia is GREECE! Read history!
  • Thessaloniki - Greece
    • Weather conditions at Thessaloniki center-Central Macedonia-Greece
« Reply #287 on: August 11, 2010, 06:47:59 AM »
First of all, I'd like to thank you for the great scripts!  :D
But, there's an error in Month Records. The day-time format in Rain Hour value is totally wrong.
I've also made the Greek translation! Here's the translation file: http://www.meteothes.gr/public/iwdl_lang_el.rar.
You have to add the Greek language in the settings file (iwdl_settings.js), by modifying this line like this:
settings["all_langs"] = [ "cz", "de", "dk", "en", "el", "fi", "fr", "hu", "it", "nl", "no", "pt", "se", "sp" ];
You can look how the Greek translation looks like, here:
http://www.meteothes.gr/iphone/
Thanos
« Last Edit: August 11, 2010, 06:51:42 AM by atsio »
Offline vogon1
  • Utrecht, NL
« Reply #288 on: August 12, 2010, 04:42:48 AM »
The date-time format bug is known, thanks for reporting anyway.
And a big thanks for your greek translation.
It looks like it is going to rain on sunday, so instead of go out and fly around, I may have some time on my hands to do some work on iWDL.
Sietse
Offline juntta
Re: Weather Display Live for the iPhone and Android -> Yr.no Forecast Issue
« Reply #289 on: August 15, 2010, 07:41:39 AM »
Hi!
And thanks for this software!
However, I have issue with forecasts in Finland. Somehow locations in Finland have this tilde & 6 digit number behind url's and that seems to break forecast. For example, forecast in Helsinki can be found at address:
http://www.yr.no/sted/Finland/Southern_Finland/Helsinki~658225/
So, is this bug or do I have modify the url somehow?
Offline gemini06720
  • Maple Bay, British Columbia, Canada
    • Tzouhalem-Maple Bay Weather, British Columbia, Canada
« Reply #290 on: August 15, 2010, 12:02:08 PM »
But it still helps if someone with an actual iphone or Android can double check with their actual cell phones.
Chris, one easy and great way to check the display of the script is to use the Apple Safari browser (there is even one version for Windows) ... so one does not even need to have a phone...  :wink:
Offline T-man
  • Finland
    • Sää Tuulensuunkaari
« Reply #291 on: August 15, 2010, 02:13:36 PM »
Quote
Just delete tilde and digits in url. At least I have been able to clean all my links.
BR - Timo
Offline juntta
« Reply #292 on: August 15, 2010, 04:24:28 PM »
BR - Timo
Well, tried that and it does work in browser (on PC) but it didn't help with iWDL. :(
Thanks anyway Timo
Offline T-man
  • Finland
« Reply #293 on: August 15, 2010, 05:17:17 PM »
Thanks anyway Timo
Ok, I see. Didn't think that detailed regarding iWDL.
BR - Timo
Offline vogon1
  • Utrecht, NL
« Reply #294 on: August 15, 2010, 07:39:57 PM »
Using Finland/Southern_Finland/Helsinki really should work.
What is the URL for your iwdl?
Sietse
Offline vogon1
  • Utrecht, NL
« Reply #295 on: August 15, 2010, 07:42:28 PM »
Sietse
Well, there were two layers of clouds and no rain, so I did some aerobatics flying between the cloud layers. No iWDL update today :(
Sietse
Offline juntta
« Reply #296 on: August 16, 2010, 11:09:53 AM »
Sietse
Actually my iWDL is in my LAN so its not open to public. Url that I use is http://meteoplug/iwdl
Offline juntta
« Reply #297 on: August 18, 2010, 09:56:40 AM »
Sietse
I dropped those numbers off from the URL but they still existed on the xml file downloaded from yr.no. Could this be reason for this?
Offline vogon1
  • Utrecht, NL
« Reply #298 on: August 18, 2010, 06:00:58 PM »
I am not sure what you mean - 'still existed on the xml file downloaded from yr.no'.
What is your setting for settings["yr.no"] ? It should be Finland/Southern_Finland/Helsinki
I just tested it in my development environment and that works.
Sietse
Offline juntta
« Reply #299 on: August 19, 2010, 02:46:13 AM »
I meant this:
Code: [Select]
<links>
<link id="xmlSource" url="http://www.yr.no/place/Finland/Southern_Finland/Helsinki~658225/forecast.xml"/>
<link id="overview" url="http://www.yr.no/place/Finland/Southern_Finland/Helsinki~658225/"/>
</links>
This propably doesnt mean anything, I mentioned it just in case.
My setting  for forecast looks like this:
settings["yr.no"] = "Finland/Southern_Finland/Helsinki/";
Could I debug iWDL somehow in my browser, if there are any errors launched by it?
