Since console was not creating the files I needed, I tried build 30, It reads about 16 or 17 records, then I get the access violations, and it stops getting the data. If I hit the openirox button, it will read the data.
Edit Better description
It might help Brian to determine the problem, if you could a couple of lines prior to the access violation and the message with the access violation.
Mike - N7DQ
make sure you have the updated libusbdll.so file in the deploy folder or in /usr/lib/ if you are using that for library files
as the problem might be when it goes to run the usbreaderirox maybe
but I will do some testing here (also testing the mac version)
I can confirm this happening here too in testing
I will investigate and hopefully be able to fix
but have visitors here today…later…
good news
I have fixed the problem
working good now
download the latest update, build 31
I ran a brief test to check that it got past the problem, it is fixed on my system too.
I’ll test a bit more later, but it looks good.
