Click in between the lines and make sure you use the shift button to move them
Sadly, you cannot import someone else's settings unless you have a 100% identical setup, from the station type to the unit settings cause if you imported my ini and and registry settings (you need both) you would end up with my settings, i.e. graph setup, main screen, login details for WU, CWOP, AWEKAS, Solar setup, graphics, webcam, should i go on? i think yiu get the idea though, it would be a major mistake for you to use someone else's. It is a shame though but thats just the way WD works, unless Windy could implement a way to export the whole Main Screen settings and a way to import them, but i have a feeling it would be a lot of work for him to do this.
Sadly you must persevere with it, sorry about that!
