cloudy
Author Topic: *** READ THIS BEFORE YOU INSTALL WD ON SNOW LEOPARD ***-> Davis VP USB  (Read 8247 times)
Offline erconway1943
  • Dallas, TX (born Buffalo, NY)
I have gone nuts for two days trying to get WD to run with a Davis Vantage Pro on Snow Leopard.  Thanks to Windy and Jmar, I got a few hints and a few kicks in the butt.  I will share the secret that made it work.
If you are going to install a Davis unit, and if you have not installed WD yet, get the USB/UART driver from SiLabs and install it FIRST  I don't know why this works, but it does.  Then install WD, configure your station and select the SLAB USB/UART driver and click it.
** DO NOT, ** DO NOT ** use the Davis driver, as it is old..
I am sure Windy and Jmar can add to this comment, but unless you have nothing to do and don't mind severe frustration, try this pearl and start enjoying WD sooner.
Thanks to all,
Ed
« Last Edit: November 01, 2009, 09:35:16 PM by windy »
Offline casper
  • www.meteodelft.nl
  • Delft-The Netherlands
    • MeteoDelft
Re: *** READ THIS BEFORE YOU INSTALL WD ON SNOW LEOPARD ***-> Davis VP USB
« Reply #1 on: November 03, 2009, 02:56:30 PM »
There is a new driver on the davis page as of today:
http://www.davisnet.com/support/weather/software_sftwr.asp
Did you try this as well?
David Vantage Pro2 Plus
2x Vantage Pro Console (1 with logger)
solar+uv sensor
heated raingauge
running on MacMini (late 2009 / 10.7.3 Lion)
wd+wdl
http://www.meteodelft.nl
« Reply #2 on: November 03, 2009, 04:21:32 PM »
No Casper, I did not, as it was not available at the time.
Davis doesn't seem to care about Apple computers, and the tech actually told me they have no one in house that is tech savvy in Apple whatsoever.
It took me two days of going about it the hard way to get up and running, but Brian (poor ole Brian) and Windy helped along with Jmar and we are up and running.
Thanks for your input.
Ed
Offline jmar
  • Halifax, Canada
    • HRM Weather
« Reply #3 on: November 03, 2009, 09:24:21 PM »
Great to see you got it all worked out Ed! Good post for new Davis and Snow Leopard users too!
iMac, 2 x Mac Mini, Mac OS X 10.6.7, Indigo integration, Web - WDL, Saratoga templates, Lightbox
Offline casper
  • www.meteodelft.nl
    • MeteoDelft
« Reply #4 on: November 04, 2009, 05:58:40 PM »
Another question: did you install the Davis program Weatherlink at all?
or did you just install the usb driver from SiLabs and after that WD?
Thanks to all,
Ed
solar+uv sensor
heated raingauge
wd+wdl
« Reply #5 on: November 06, 2009, 12:35:46 PM »
I did not use weatherlink.  I started clean, went to Silicon Labs site and downloaded the updated driver.  Installed that first and by itself, then reinstalled WD.  Running like a screaming eagle now.
Offline casper
  • www.meteodelft.nl
    • MeteoDelft
« Reply #6 on: November 08, 2009, 03:33:48 PM »
Worked for me as well.
thanks!
solar+uv sensor
heated raingauge
wd+wdl
« Reply #7 on: November 13, 2009, 12:31:36 PM »
Well I did exactly what was suggested but it crashes as soon as I start the prog. Freezes & then crashes. Suggestions????
Offline casper
  • www.meteodelft.nl
    • MeteoDelft
« Reply #8 on: November 13, 2009, 01:23:21 PM »
new installation of Snow on a clean machine?
first thing you did was installing the usb-driver?
connected the envoy or station after that?
then installed WD?
choose the right usb driver in setup?
In this order it should work
solar+uv sensor
heated raingauge
wd+wdl
Offline jmar
  • Halifax, Canada
    • HRM Weather
« Reply #9 on: November 17, 2009, 03:13:43 PM »
Critically important for Davis users- If you are either upgrading to Snow Leopard, OR installing the Davis drivers from either Davis or Silabs, then installing WD Mac after, you MUST repair permissions on the hard drive BEFORE installing WD Mac. One of the 3 combinations mentioned here is breaking the permissions on the /usr/lib/ folder and not allowing us to install the correct lib files. Then after repairing disk permissions, install WD Mac and proceed to set up normally. It's ok if you already installed WD first and then came here and read this, you can reinstall again after performing the steps above.
To repair permissions - Go to Utilities folder, open Disk Utility, select only your MacIntosh HD (the system hard disk) and click on Repair Permissions. Should take about 10 minutes and you will likely get a ton of messages in the window. (Would be nice to know which of the drivers above is responsible so wecan inform the vendor) or if it's a Snow related breakage, it will just say repairing /usr/lib/ and at least we will know.
This should be performed before AND after any system upgrade as good system maintenance, and after installing third party drivers such as mentioned above.
All the best
Jmar
Offline Kamakzie
  • Cedar Springs, MI
« Reply #10 on: March 14, 2010, 08:17:25 PM »
Grrr followed instructions but I can't get anything in the USB to serial except /Dev.  Not sure what I'm doing wrong.
« Reply #11 on: March 14, 2010, 09:34:14 PM »
make sure the davis USB VP is connected to the Mac when installing the Silabs USB driver for the Mac
Offline Kamakzie
  • Cedar Springs, MI
« Reply #12 on: March 14, 2010, 09:38:05 PM »
Yup it was plugged in during the install.  I just can't figure out what /dev is the weather station.
Offline Kamakzie
  • Cedar Springs, MI
« Reply #13 on: March 15, 2010, 08:32:28 PM »
Any ideas?  In windows 7 its assigned Com 3.  What would it be in Mac OS?
Offline NBH
  • Stenestad at the top of Söderåsen in south Sweden
  • Stenestad Sweden
    • Stenstad Weather
« Reply #14 on: March 18, 2010, 03:53:13 AM »
Quote
Hi I'm using this:
/dev/tty.SLAB_USBtoUART
(see attached picture)
Bertil
Mac mini, 2.26 GHz Intel Core 2 Duo, 4 GB, OS X 10.7.3 Lion
