I’ve been meaning to place a space weather page on my site for some time now. Thanks very much Mike
I like the sun images you have, and the other stuff. I might fit them into my script when I get time.
Mike
Good one Mike!
Great script set, Mike! Thanks!!
My page is at http://saratoga-weather.org/space-weather.php
Ken
Quick question - I uploaded the files per instructions (Thanks Mike!!) and tested the wxspace.php at http://www.tuscawilla-weather.net/wxspace.php Seems I’m not getting any graphics. Could that be the cache file writing restriction on e-Rice.net? If so, what are the cache files? I think if I create them in the website directory at e-Rice and set the permissions to 666 then the scripts can use the cache file write that it needs to display graphics? Am I on the right track??
Any help appreciated.
Greg.
I’m also on E-Rice.
I simply uploaded the files that Mike said was needed, and it worked.
I didn’t have to change any permissions.
Hmmmm. Now Im really puzzled.
All files were put in the same directory as wxspace.php?
Hi All,
Thanks Mike for the script. Got mine to work just fine. Plug n’ Play. No fuss, just load and go. My page is at http://www.dwayneyamato.com/wx/wxspace.php.
Will get it on the menu bar as time permits.
Thank you again for a wonderful job.
–Stan Y.
Maui, Hawaii
KH6HHG
Also on e-rice, also not getting graphics. http://www.cavecountryweather.com/wxspace.php
I looks to me like the script is calling for a .txt cache. Is this something that we need to create manually and then change the permissions on?
hi
Tried installing this but not getting the graphics just “error 003” Maybe because I’m using the worldmml template though.
http://www.weybourneweather.co.uk/wxspace.php
Phil
Samething here on e-rice. I did manage to get a few graphics going after fighting with it for a bit. I’ll try and finish it today.
Put the chmod permissions on 777, but after update got this
d0
403 ForbiddenForbidden
You don't have permission to access /today.html on this server.
in spaceweather-current.txt
emptied it have forecast again and put chmod on 755, observing now
I have all of my files set to 777, thats the only way i could get them to work.
Are you on e-rice? I tried changing my files to 777, but it did not save.
Im on e-rice. Thats odd that its not saving. Not that it proably matters but, are you using filezilla?
Why struggle with a web host that restricts things and makes it harder?
May I suggest making a switch to HostGator
Info at my computer repair site
Be sure to select “Linux Web Hosting” when you start your hosting account. If your web site requires any interactive scripts like contact forms, blogs, forums, e-commerce, etc. then I very highly recommend “Linux Web Hosting” rather than “Windows Web Hosting” because I have fewer problems with it.
i dont think e-rice is restricting things so this script wont work, cause i did get a few pics to work, Its just taking a few extra things to get it to work.
Just my personal $ 0.02 but I think it’s a valid choice because most people do not need, or wish, to spend more than the minimum necessary for a hobby website. According to the info posted on Hostgator’s site they pay more in commission to affiliates (such as yourself) than we users of e-rice and other low cost hosts pay for hosting, and at the end of the day what you get is hosting with more advanced capabilities but on a shared server owned by the same
Hi all,
I am with 1and1 and it is not working. The page comes up properly but not the pictures. I have changed permissions to 777.
