If you are using this script on E-Rice, you may want to check to see if the images are being updated. Mine were not, no matter what the permissions, etc. were set to. Even though php_info says that curl is supported, I had to set use_curl=0 and now all is fine.
Check by looking at the real time solar wind image as it's easy to see the date/time. The date and time should be be changing as time goes by. If it isn't, then you may have the same problem I did.
Derek
