cloudy
Author Topic: ERROR: Invalid floating point operation at time/date  (Read 1739 times)
Offline WanetaLake
  • FingerLakes of NY
    • Waneta Lake WebCam and Weather
« on: May 01, 2004, 04:10:40 PM »
On April 27th at midnight my 10.10m crashed.  I was out of town, I returned, cleared the weather station's memory, cleaned invalid data from the log files, updated to 10.10t.
The error occurs every minute on the minute.   I cannot make it stop.
Any ideas.   I'm sure it is curropt data somewhere.
www.wanetalake.com
Davis WMII   W2K  WD 10.10t  broadband.     remote location 600 miles from my house!
Davis VP2  W2K  Broadband.
Online Weather Display
« Reply #1 on: May 01, 2004, 05:49:49 PM »
try:
exit wd, then delete the datafile (s) latest.inf, or latestindoor.inf, or graphdata.inf or graphdata2.inf or graphdata3.inf
then restart wd
Offline WanetaLake
  • FingerLakes of NY
Solved!
« Reply #2 on: May 02, 2004, 12:47:21 AM »
That Worked.  Thank You.
I deleted all the .inf files you suggested.
It is hard to maintain my site while traveling.
Offline niko
  • syzygy
  • Global Moderator
  • Northern California, U.S.A.
Help! Floating point error, but this doesn't fix it
« Reply #3 on: June 03, 2004, 12:17:03 AM »
My remote system crashed and now gives the floating point error when restarted. I did as suggested above but it doesn't solve the problem. Now what  :?
« Reply #4 on: June 03, 2004, 05:43:46 AM »
try:
action, convert wd log files to graphs
then choose the file 62004lg.txt
then click on convert
then restart wd
let me know...
Offline niko
  • syzygy
  • Global Moderator
« Reply #5 on: June 03, 2004, 02:26:35 PM »
Sorry, that didn't fix it.  :cry:
« Reply #6 on: June 03, 2004, 05:13:32 PM »
ohhh
now, can you zip and email me the files that its most likely to be, so i can try and fix/duplicate here:
wdisplay.ini from c:\windows or c:\winnt
datafiles:
latest.inf
latestindoor.inf
latesttime.inf
month62004.inf
graphdata.inf
graphdata2.inf
graphdata3.inf
graphdata4.inf
24hourrain.inf
direction2.inf
monthextra62004.inf
monthextravp62004.inf  (that is a file you could try deleting)
fwi.inf
Offline niko
  • syzygy
  • Global Moderator
« Reply #7 on: June 03, 2004, 05:38:55 PM »
Thanks Brian, I'll do that tonight.
« Reply #8 on: June 03, 2004, 06:01:43 PM »
the other thing to try is:
install to a new directory, with a file called 2wd.txt there....in that directory...
then it should fire up ok, like brand new
then copy over the datafiles, one at a time, from the list above, until you find which one is the culprit (this will take a while though :(
Offline niko
  • syzygy
  • Global Moderator
« Reply #9 on: June 03, 2004, 07:11:38 PM »
OK, I give the 2nd iteration a try. Is there anything obvious that I would see if I look in the data files?
Thank goodness for VNC remote access  :)
« Reply #10 on: June 03, 2004, 07:17:28 PM »
maybe any data files that are zero size
or any graphdata files that are big in size?
Offline niko
  • syzygy
  • Global Moderator
« Reply #11 on: June 04, 2004, 02:26:20 PM »
Deleting the June files got rid of the divide by zero but the VP download wouldn't abort and always crashed WD. I installed in a new folder, that ran OK, copied over all the data files through May '04 and it's still OK. Now I'm trying to get the web stuff working as it was before and figuring out what I've lost :cry:  :cry:
« Reply #12 on: June 04, 2004, 05:37:13 PM »
also copy across all the web files from the web files folder...
did you back up those june files?
(if so, please zip and email to me)
sorry this happened!
Offline niko
  • syzygy
  • Global Moderator
« Reply #13 on: June 04, 2004, 07:02:26 PM »
Quote from: windy
Done, I sent you all the files that had a June 2004 created or modified date, not sure if the dates come through the zip process.
Quote
sorry this happened!]
No sweat, Bill Gates never helped me when I had a problem with any of his sofware  :P
