Weather Display > WD Bug Reports
Max temp reset
hcorrin:
in setup under values reset time option which one is ticked.
Koen De Vuyst:
Today everything worked fine. All values where reset at midnight. I rebooted my PC every night automatically at 0:05. Yesterday I changed that to 1:20. Maybe that may caused the problem.
Weather Display:
yes, that will be related,as data like the daily hi/lo is only saved every 10 minutes, i.e at 10 minutes past the hour....i.e the reboot at 5 minutes past would have been before the data was saved
also, did you see in the latest beta version, i have windspee increase offset for a certain wind direciton range added? (i.e for if your anenometer is sheltered from a certain wind direction
Koen De Vuyst:
Yes I saw, good idea to add that availability.
Greetz,
Koen
Stuntman:
Interestingly enough, my WD setup isn't resetting gusts or high temps either! Mine is supposed to reset at 12:01 a.m. each evening, which it appears to do, but the values are not reset..
Hmm...
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
