Author Topic: Testtags V1.05 available (now V1.06)  (Read 2367 times)
Offline saratogaWX
    • Saratoga Weather
« on: July 12, 2009, 04:29:56 AM »
Thanks to the kind permission of both Mike and Scott, I've combined all the tags required for the Printable Weather Flyer, Alternative Dashboard and High/Low/Average page into one testtags.txt .
I used this Perl program to spot any duplicated tags in the set, and remove them so your testtags.txt->testtags.php will be of smaller size, and WD will have less work to do the substitutions.  Don't know if the latter will make much difference, but a smaller-sized testtags.php will make for improved upload times (and maybe just a skosh improvement in page loads).
Here's the Perl script I used to generate the new testtags.txt file
Code: [Select]
#!/usr/bin/perl
# purpose:  read testtags.txt file and spot duplicate tags
# Generate two output files:
#  testtags-commented.txt with each line with a duplicated tag commented out
#  testtags-nodupes.txt with duplicated tag lines omitted.
# author: Ken True - Saratoga-weather@org
# Version 1.00 - 11-Jul-2009 -- initial release
# Versuib 1.01 - 12-Jul-2009 -- replace " with ' in strings, formatted output better
$inFile = "testtags-original.txt";
$outFile = "testtags-commented.txt";
$newFile = "testtags.txt";
%tags = ();
%duptags = ();
$lineCount = 0;
$outCount = 0;
$newCount = 0;
$tagCount = 0;
$dupTagCount = 0;
$commentCount = 0;
print "Opening $inFile for analysis.\n";
open (IN,"<$inFile") or die "--Unable to open for reading $inFile: $! \n";
open (OUT,">$outFile") or die "--Unable to open for writing $outFile: $! \n";
open (NEW,">$newFile") or die "--Unable to open for writing $newFile: $! \n";
 while (<IN>) {
   chomp;
   $inrec = $_;
   $inrec =~ s/=\s*"(.*)"/= '$1'/g;
   $lineCount++;
   if ( $inrec =~ m/^\s*\/\// ) {
     print OUT "$inrec\n";
     $outCount++;
     print NEW "$inrec\n";
     $newCount++;
     next;
   if ($inrec =~ m/^\s*#/ ) {
     $outCount++;
     $newCount++;
     next;
   if ( $inrec !~ m/^\$(\S+)\s*=\s*[\'|\"](\S+)[\'|\"]/) {
     $outCount++;
     $newCount++;
     next;
   $phpname = $1;
   $wdname = $2;
   if ($tags{$phpname}) {
     $dupTagCount++;
     $tags{$phpname} .= "\tdup=$wdname:$lineCount";
     $duptags{$phpname}++;
     $commentCount++;
     $inrec = "//--duplicate-- " . $inrec;
   } else {
     $tags{$phpname} = "first=$wdname:$lineCount";
     $tagCount++;
     $newCount++;
   $outCount++;
close IN;
close OUT;
print "..$lineCount lines in $inFile.\n";
print "..$tagCount tags found.\n";
print "..$outCount lines written to $outFile with $commentCount duplicated tags commented out.\n";
print "..$newCount lines written to $newFile with duplicated lines removed.\n";
print "..$dupTagCount duplicate tags found (first=WDTAG:lineno dup=WDTAG:lineno ):\n";
foreach $key (sort keys %duptags) {
  print "\$$key\t" . $tags{$key} . "\n";
which returned the following results
Quote
Opening testtags-original.txt for analysis.
..1079 lines in testtags-original.txt.
..602 tags found.
..1079 lines written to testtags-commented.txt with 207 duplicated tags commented out.
..872 lines written to testtags.txt with duplicated lines removed.
..207 duplicate tags found (first=WDTAG:lineno dup=WDTAG:lineno ):
$VPet   first=%VPet%:403   dup=%VPet%:989
$VPetmonth   first=%VPetmonth%:404   dup=%VPetmonth%:677   dup=%VPetmonth%:854   dup=%VPetmonth%:990
$WUmaxtemp   first=%WUmaxtemp%:135   dup=%WUmaxtemp%:657   dup=%WUmaxtemp%:834
$WUmaxtempr   first=%WUmaxtempr%:138   dup=%WUmaxtempr%:659   dup=%WUmaxtempr%:836
$WUmaxtempryr   first=%WUmaxtempryr%:140   dup=%WUmaxtempryr%:661   dup=%WUmaxtempryr%:838
$WUmintemp   first=%WUmintemp%:136   dup=%WUmintemp%:658   dup=%WUmintemp%:835
$WUmintempr   first=%WUmintempr%:139   dup=%WUmintempr%:660   dup=%WUmintempr%:837
$WUmintempryr   first=%WUmintempryr%:141   dup=%WUmintempryr%:662   dup=%WUmintempryr%:839
$airdensity   first=%airdensity%:653   dup=%airdensity%:830
$apparentsolartempc   first=%apparentsolartempc%:131   dup=%apparentsolartempc%:685   dup=%apparentsolartempc%:747
$apparentsolartempf   first=%apparentsolartempf%:133   dup=%apparentsolartempf%:684   dup=%apparentsolartempf%:746
$avtempweek   first=%avtempweek%:625   dup=%avtempweek%:784
$burntime   first=%burntime%:230   dup=%burntime%:708   dup=%burntime%:762
$cddday   first=%cddday%:644   dup=%cddday%:817
$cddmonth   first=%cddmonth%:645   dup=%cddmonth%:818
$cddyear   first=%cddyear%:646   dup=%cddyear%:819
$chandler   first=%chandler%:709   dup=%chandler%:763
$changeinday   first=%changeinday%:655   dup=%changeinday%:832
$coldestdayonrecord   first=%coldestdayonrecord%:627   dup=%coldestdayonrecord%:786
$coldestnightonrecord   first=%coldestnightonrecord%:629   dup=%coldestnightonrecord%:788
$dayswithrain   first=%dayswithrain%:203   dup=%dayswithrain%:932
$dayswithrainyear   first=%dayswithrainyear%:204   dup=%dayswithrainyear%:933
$etcurrentweek   first=%etcurrentweek%:680   dup=%etcurrentweek%:858
$firewi   first=%FWIfwi%:624   dup=%FWIfwi%:783
$fullmoondate   first=%fullmoondate%:65   dup=%fullmoondate%:690   dup=%fullmoondate%:752
$hddday   first=%hddday%:641   dup=%hddday%:814
$hddmonth   first=%hddmonth%:642   dup=%hddmonth%:815
$hddyear   first=%hddyear%:643   dup=%hddyear%:816
$highbaro   first=%highbaro%:406   dup=%highbaro%:879
$highbarot   first=%highbarot%:407   dup=%highbarot%:881
$highsolaryest   first=%highsolaryest%:408   dup=%highsolaryest%:906
$highsolaryesttime   first=%highsolaryesttime%:409   dup=%highsolaryesttime%:925
$highuvyest   first=%highuvyest%:228   dup=%highuvyest%:913
$highuvyesttime   first=%highuvyesttime%:229   dup=%highuvyesttime%:926
$lighteningcountlast12hour   first=%lighteningcountlast12hour%:699   dup=%lighteningcountlast12hour%:757
$lighteningcountlast30minutes   first=%lighteningcountlast30minutes%:700   dup=%lighteningcountlast30minutes%:758
$lighteningcountlast5minutes   first=%lighteningcountlast5minutes%:698   dup=%lighteningcountlast5minutes%:756
$lighteningcountlasthour   first=%lighteningcountlasthour%:696   dup=%lighteningcountlasthour%:754
$lighteningcountlastminute   first=%lighteningcountlastminute%:697   dup=%lighteningcountlastminute%:755
$lighteningcountlasttime   first=%lighteningcountlasttime%:701   dup=%lighteningcountlasttime%:759
$lighteningcountmonth   first=%lighteningcountmonth%:702   dup=%lighteningcountmonth%:760
$lighteningcountyear   first=%lighteningcountyear%:703   dup=%lighteningcountyear%:761
$maxaverageyest   first=%maxaverageyest%:411   dup=%maxaverageyest%:871   dup=%maxaverageyest%:928
$maxaverageyestt   first=%maxaverageyestt%:412   dup=%maxaverageyestt%:927
$maxbaroyest   first=%maxbaroyest%:416   dup=%maxbaroyest%:564   dup=%maxbaroyest%:883
$maxbaroyestt   first=%maxbaroyestt%:417   dup=%maxbaroyestt%:565   dup=%maxbaroyestt%:930
$maxgustyest   first=%maxgustyest%:419   dup=%maxgustyest%:554   dup=%maxgustyest%:872
$maxgustyestt   first=%maxgustyestt%:420   dup=%maxgustyestt%:555   dup=%maxgustyestt%:929
$maxheatweek   first=%maxheatweek%:651   dup=%maxheatweek%:712
$maxsolarfortime   first=%maxsolarfortime%:688   dup=%maxsolarfortime%:750   dup=%maxsolarfortime%:857
$maxtempyestt   first=%maxtempyestt%:148   dup=%maxtempyestt%:921
$minbaroyest   first=%minbaroyest%:566   dup=%minbaroyest%:884
$minbaroyestt   first=%minbaroyestt%:567   dup=%minbaroyestt%:931
$minchillweek   first=%minchillweek%:648   dup=%minchillweek%:821
$minchillyest   first=%minchillyest%:423   dup=%minchillyest%:650   dup=%minchillyest%:825
$minchillyestt   first=%minchillyestt%:424   dup=%minchillyestt%:923
$mintempyestt   first=%mintempyestt%:150   dup=%mintempyestt%:922
$minwindch   first=%minwindch%:425   dup=%minwindch%:647   dup=%minwindch%:820
$minwindcht   first=%minwindcht%:426   dup=%minwindcht%:649   dup=%minwindcht%:822
$monthname   first=%monthname%:42   dup=%monthname%:91
$monthrn   first=%monthrn%:200   dup=%monthrn%:678   dup=%monthrn%:855
$mrecordhighavwindday   first=%mrecordhighavwindday%:427   dup=%mrecordhighavwindday%:965
$mrecordhighavwindmonth   first=%mrecordhighavwindmonth%:428   dup=%mrecordhighavwindmonth%:966
$mrecordhighbaro   first=%mrecordhighbaro%:430   dup=%mrecordhighbaro%:579
$mrecordhighbaroday   first=%mrecordhighbaroday%:431   dup=%mrecordhighbaroday%:580   dup=%mrecordhighbaroday%:973
$mrecordhighbaromonth   first=%mrecordhighbaromonth%:432   dup=%mrecordhighbaromonth%:581   dup=%mrecordhighbaromonth%:974
$mrecordhighbaroyear   first=%mrecordhighbaroyear%:433   dup=%mrecordhighbaroyear%:582
$mrecordhighgustday   first=%mrecordhighgustday%:246   dup=%mrecordhighgustday%:969
$mrecordhighgustmonth   first=%mrecordhighgustmonth%:434   dup=%mrecordhighgustmonth%:556   dup=%mrecordhighgustmonth%:970
$mrecordhighgustyear   first=%mrecordhighgustyear%:435   dup=%mrecordhighgustyear%:557
$mrecordhightemp   first=%mrecordhightemp%:436   dup=%mrecordhightemp%:569   dup=%mrecordhightemp%:859
$mrecordhightempday   first=%mrecordhightempday%:437   dup=%mrecordhightempday%:570   dup=%mrecordhightempday%:941
$mrecordhightempmonth   first=%mrecordhightempmonth%:438   dup=%mrecordhightempmonth%:571   dup=%mrecordhightempmonth%:942
$mrecordhightempyear   first=%mrecordhightempyear%:439   dup=%mrecordhightempyear%:572
$mrecordlowbaroday   first=%mrecordlowbaroday%:585   dup=%mrecordlowbaroday%:977
$mrecordlowbaromonth   first=%mrecordlowbaromonth%:586   dup=%mrecordlowbaromonth%:978
$mrecordlowchill   first=%mrecordlowchill%:440   dup=%mrecordlowchill%:863
$mrecordlowchillday   first=%mrecordlowchillday%:441   dup=%mrecordlowchillday%:949
$mrecordlowchillmonth   first=%mrecordlowchillmonth%:442   dup=%mrecordlowchillmonth%:950
$mrecordlowtemp   first=%mrecordlowtemp%:444   dup=%mrecordlowtemp%:574   dup=%mrecordlowtemp%:860
$mrecordlowtempday   first=%mrecordlowtempday%:445   dup=%mrecordlowtempday%:575   dup=%mrecordlowtempday%:943
$mrecordlowtempmonth   first=%mrecordlowtempmonth%:446   dup=%mrecordlowtempmonth%:576   dup=%mrecordlowtempmonth%:944
$mrecordlowtempyear   first=%mrecordlowtempyear%:447   dup=%mrecordlowtempyear%:577
$nextnewmoon   first=%nextnewmoon%:61   dup=%nextnewmoon%:691   dup=%nextnewmoon%:753
$raincurrentweek   first=%raincurrentweek%:451   dup=%raincurrentweek%:679   dup=%raincurrentweek%:856
$recorddailyrain   first=%recorddailyrain%:813   dup=%recorddailyrain%:940
$recordhightemp   first=%recordhightemp%:630   dup=%recordhightemp%:789
$recordhightempday   first=%recordhightempday%:632   dup=%recordhightempday%:791
$recordhightempmonth   first=%recordhightempmonth%:631   dup=%recordhightempmonth%:790
$recordhightempyear   first=%recordhightempyear%:633   dup=%recordhightempyear%:792
$recordlowchill   first=%recordlowchill%:652   dup=%recordlowchill%:827
$recordlowchillday   first=%recordlowchillday%:639   dup=%recordlowchillday%:798
$recordlowchillmonth   first=%recordlowchillmonth%:638   dup=%recordlowchillmonth%:797
$recordlowchillyear   first=%recordlowchillyear%:640   dup=%recordlowchillyear%:799
$recordlowtemp   first=%recordlowtemp%:634   dup=%recordlowtemp%:793
$recordlowtempday   first=%recordlowtempday%:636   dup=%recordlowtempday%:795
$recordlowtempmonth   first=%recordlowtempmonth%:635   dup=%recordlowtempmonth%:794
$recordlowtempyear   first=%recordlowtempyear%:637   dup=%recordlowtempyear%:796
$snowdaysthismonth   first=%snowdaysthismonth%:266   dup=%snowdaysthismonth%:675   dup=%snowdaysthismonth%:852
$snowdaysthisyear   first=%snowdaysthisyear%:267   dup=%snowdaysthisyear%:676   dup=%snowdaysthisyear%:853
$snowmonthcm   first=%snowmonthcm%:256   dup=%snowmonthcm%:670   dup=%snowmonthcm%:848
$snowmonthin   first=%snowmonthin.%:253   dup=%snowmonthin.%:665   dup=%snowmonthin.%:843
$snownowcm   first=%snownowcm%:263   dup=%snownowcm%:672   dup=%snownowcm%:850
$snownowin   first=%snownowin.%:262   dup=%snownowin.%:667   dup=%snownowin.%:845
$snowseasoncm   first=%snowseasoncm%:255   dup=%snowseasoncm%:669   dup=%snowseasoncm%:847
$snowseasonin   first=%snowseasonin.%:252   dup=%snowseasonin.%:664   dup=%snowseasonin.%:842
$snowtodaycm   first=%snowtodaycm%:257   dup=%snowtodaycm%:671   dup=%snowtodaycm%:849
$snowtodayin   first=%snowtodayin.%:254   dup=%snowtodayin.%:666   dup=%snowtodayin.%:844
$snowyesterday   first=%snowyesterday%:258   dup=%snowyesterday%:674   dup=%snowyesterday%:840
$solarnoon   first=%solarnoon%:654   dup=%solarnoon%:831
$sunshinehourstodateday   first=%sunshinehourstodateday%:686   dup=%sunshinehourstodateday%:748   dup=%sunshinehourstodateday%:900
$sunshinehourstodatemonth   first=%sunshinehourstodatemonth%:687   dup=%sunshinehourstodatemonth%:749   dup=%sunshinehourstodatemonth%:901
$vpconsolebattery   first=%vpconsolebattery%:623   dup=%vpconsolebattery%:782
$vpissstatus   first=%vpissstatus%:621   dup=%vpissstatus%:780
$vpreception2   first=%vpreception2%:622   dup=%vpreception2%:781
$warmestdayonrecord   first=%warmestdayonrecord%:626   dup=%warmestdayonrecord%:785
$warmestnightonrecord   first=%warmestnightonrecord%:628   dup=%warmestnightonrecord%:787
$wetbulb   first=%wetbulb%:689   dup=%wetbulb%:751
$windruntodatethismonth   first=%windruntodatethismonth%:455   dup=%windruntodatethismonth%:983
$windruntodatethisyear   first=%windruntodatethisyear%:456   dup=%windruntodatethisyear%:984
$windruntoday   first=%windruntoday%:457   dup=%windruntoday%:981
$yearrn   first=%yearrn%:201   dup=%yearrn%:869
$yeartodateavwind   first=%yeartodateavwind%:877   dup=%yeartodateavwind%:887
$yeartodategstwind   first=%yeartodategstwind%:878   dup=%yeartodategstwind%:888
$yesterdayrain   first=%yesterdayrain%:211   dup=%yesterdayrain%:870
$yrecordhighavwindday   first=%yrecordhighavwindday%:459   dup=%yrecordhighavwindday%:967
$yrecordhighavwindmonth   first=%yrecordhighavwindmonth%:460   dup=%yrecordhighavwindmonth%:968
$yrecordhighbaro   first=%yrecordhighbaro%:462   dup=%yrecordhighbaro%:599   dup=%yrecordhighbaro%:891
$yrecordhighbaroday   first=%yrecordhighbaroday%:463   dup=%yrecordhighbaroday%:600   dup=%yrecordhighbaroday%:975
$yrecordhighbaromonth   first=%yrecordhighbaromonth%:464   dup=%yrecordhighbaromonth%:601   dup=%yrecordhighbaromonth%:976
$yrecordhighbaroyear   first=%yrecordhighbaroyear%:465   dup=%yrecordhighbaroyear%:602
$yrecordhighgustday   first=%yrecordhighgustday%:466   dup=%yrecordhighgustday%:560   dup=%yrecordhighgustday%:971
$yrecordhighgustmonth   first=%yrecordhighgustmonth%:467   dup=%yrecordhighgustmonth%:561   dup=%yrecordhighgustmonth%:972
$yrecordhighgustyear   first=%yrecordhighgustyear%:468   dup=%yrecordhighgustyear%:562
$yrecordhightemp   first=%yrecordhightemp%:469   dup=%yrecordhightemp%:589   dup=%yrecordhightemp%:866
$yrecordhightempday   first=%yrecordhightempday%:470   dup=%yrecordhightempday%:590   dup=%yrecordhightempday%:945
$yrecordhightempmonth   first=%yrecordhightempmonth%:471   dup=%yrecordhightempmonth%:591   dup=%yrecordhightempmonth%:946
$yrecordhightempyear   first=%yrecordhightempyear%:472   dup=%yrecordhightempyear%:592
$yrecordlowbaro   first=%yrecordlowbaro%:604   dup=%yrecordlowbaro%:892
$yrecordlowbaroday   first=%yrecordlowbaroday%:605   dup=%yrecordlowbaroday%:979
$yrecordlowbaromonth   first=%yrecordlowbaromonth%:606   dup=%yrecordlowbaromonth%:980
$yrecordlowchill   first=%yrecordlowchill%:473   dup=%yrecordlowchill%:868
$yrecordlowchillday   first=%yrecordlowchillday%:474   dup=%yrecordlowchillday%:951
$yrecordlowchillmonth   first=%yrecordlowchillmonth%:475   dup=%yrecordlowchillmonth%:952
$yrecordlowtemp   first=%yrecordlowtemp%:477   dup=%yrecordlowtemp%:594   dup=%yrecordlowtemp%:867
$yrecordlowtempday   first=%yrecordlowtempday%:478   dup=%yrecordlowtempday%:595   dup=%yrecordlowtempday%:947
$yrecordlowtempmonth   first=%yrecordlowtempmonth%:479   dup=%yrecordlowtempmonth%:596   dup=%yrecordlowtempmonth%:948
$yrecordlowtempyear   first=%yrecordlowtempyear%:480   dup=%yrecordlowtempyear%:597
$yrecordwindgust   first=%yrecordwindgust%:481   dup=%yrecordwindgust%:559   dup=%yrecordwindgust%:899
I've attached testtags-original (the 4 combined), testtags-commented (with the duplicated lines commented out), and finally
testtags.txt (the new 1.05V1.06 version with no duplicated tags).
I'll be adding that to the distributions tonight.
Ken
EDIT: updated with testtags.txt V1.06 to support Scott's Alternative Dashboard V4.00 release.
« Last Edit: July 13, 2009, 12:47:34 AM by ktrue »
Ken True
Saratoga Weather
CWOP: CW1792
WeatherUnderground: KCASARAT1
Offline saratogaWX
    • Saratoga Weather
Re: Testtags V1.05 available
« Reply #1 on: July 12, 2009, 04:46:20 AM »
Distributions now updated with V1.05 of testtags.txt
Ken
Ken True
Saratoga Weather
CWOP: CW1792
abaldish
  • Guest
« Reply #2 on: July 12, 2009, 05:11:31 AM »
Just placed the new testtags in place now.
Offline MCHALLIS
  • Long Beach, WA USA
« Reply #3 on: July 12, 2009, 06:31:18 AM »
Thanks Ken  :D
Offline jahuff
  • Northern New Hampshire, USA
    • Weather Data Pittsburg, NH
« Reply #4 on: July 12, 2009, 11:29:49 AM »
Thanks Ken, this makes it easy to update.
John
Offline HometownZone
  • Scott
  • Webster Weather LIVE Scripts
  • Webster, MN, USA
« Reply #5 on: July 12, 2009, 12:27:45 PM »
Thanks Ken!!  They work very well!
Scott
Scott
www.WebsterWeatherLIVE.com
Windows XP Pro(SP3), 4G Ram, QuickCam Pro 9000, Davis Vantage Pro II w/Solar/UV & Heated Rain Catcher, WXSim, 1-Wire: Lightning, Leaf, soil moist/tmp
Offline Stronghurst
  • You Are Never Alone With a Schizoid
  • Stronghurst,IL USA
    • Burgus Computers
« Reply #6 on: July 12, 2009, 12:43:56 PM »
Thank you
Mark
http://www.burgus.org
Every day is a good day.  Just that some days are better than others.
Offline charmed
  • Fredericton, New Brunswick
    • Fredericton Area Weather
« Reply #7 on: July 12, 2009, 05:07:06 PM »
My high temp, UV etc. are not updating I'll have to look into this evening.
Rick
Offline charmed
« Reply #8 on: July 12, 2009, 05:15:22 PM »
False alarm I just happened to be viewing just as the sun came out and was waffling on the temp and UV in between testtag updates.
Rick
Offline wslangerak
  • Kees
  • Langerak (ZH) - The Netherlands
    • Weerstation Langerak
« Reply #9 on: July 12, 2009, 06:07:18 PM »
Thanks Ken, they work a treat!
the delicate sound of thunder.....
Offline MCHALLIS
« Reply #10 on: July 12, 2009, 09:29:43 PM »
I wish the winds did not have decimal places.
I read somewhere that mph wind measurements usually do not need decimals.
$avgspd =  '4.5 mph';   // average wind speed (current)
$gstspd =  '3.0 mph';   // current/gust wind speed
$maxgst =  '11.0 mph';   // today's maximum wind speed
$maxgstt =  '12:39 PM';   // time this occurred
$maxgsthr =  '11.0 mph NNE';   // maximum gust last hour
Wonder why baro has .in instead of in.
$baro = '30.050 .in';  // current barometer
this one too...
$vpstormrain = '0.00 .in';           //Davis VP Storm rain value
Rain has in. and looks OK
$dayrn =  '0.00 in.';   // today's rain
$monthrn =  '0.00 in.';   // rain so far this month
$yearrn =  '0.00 in.';   // rain so far this year
Offline saratogaWX
    • Saratoga Weather
« Reply #11 on: July 12, 2009, 10:41:28 PM »
Just out.. V1.06 of testtags.txt to support Scott's Alternative Dashboard V4.00.
Download a new distribution or just use the attached V1.06 testtags.txt to replace your existing one.
Ken
Ken True
Saratoga Weather
CWOP: CW1792
Offline saratogaWX
    • Saratoga Weather
« Reply #12 on: July 12, 2009, 11:24:22 PM »
this one too...
I've noticed those too, Mike -- it's why I tend to use strip_units(), then sprintf() to set the decimals I want, and use the $uom... strings in the dashboard/gizmo/Settings.php to make units displays uniform :)
Ken
Ken True
Saratoga Weather
CWOP: CW1792
abaldish
  • Guest
« Reply #13 on: July 12, 2009, 11:34:36 PM »
Thanks for the updated 1.05 ken you are the man, and so are the others.
Offline MCHALLIS
« Reply #14 on: July 12, 2009, 11:55:03 PM »
Ken
Works for me, thanks  :)
