ktrue
Junior Weather Controller
OfflineLocation: Saratoga, CA, USA 37:16:28N, 122:01:23W - Elev: 374ft. Station Type: Davis VP1+ FARS, Boltek-PCI, NexStorm StormVue WASP2, GRLevel3, WXSIM
Posts: 3,906 Local Time: Thursday 09:27
« on: July 12, 2009, 04:29:56 AM » |
Thanks to the kind permission of both Mike and Scott, I've combined all the tags required for the Printable Weather Flyer, Alternative Dashboard and High/Low/Average page into one testtags.txt . I used this Perl program to spot any duplicated tags in the set, and remove them so your testtags.txt->testtags.php will be of smaller size, and WD will have less work to do the substitutions. Don't know if the latter will make much difference, but a smaller-sized testtags.php will make for improved upload times (and maybe just a skosh improvement in page loads). Here's the Perl script I used to generate the new testtags.txt file #!/usr/bin/perl # # purpose: read testtags.txt file and spot duplicate tags # Generate two output files: # testtags-commented.txt with each line with a duplicated tag commented out # testtags-nodupes.txt with duplicated tag lines omitted. # # author: Ken True - Saratoga-weather@org # # Version 1.00 - 11-Jul-2009 -- initial release # Versuib 1.01 - 12-Jul-2009 -- replace " with ' in strings, formatted output better #
$inFile = "testtags-original.txt"; $outFile = "testtags-commented.txt"; $newFile = "testtags.txt";
%tags = (); %duptags = (); $lineCount = 0; $outCount = 0; $newCount = 0; $tagCount = 0; $dupTagCount = 0; $commentCount = 0;
print "Opening $inFile for analysis.\n";
open (IN,"<$inFile") or die "--Unable to open for reading $inFile: $! \n"; open (OUT,">$outFile") or die "--Unable to open for writing $outFile: $! \n"; open (NEW,">$newFile") or die "--Unable to open for writing $newFile: $! \n";
while (<IN>) { chomp; $inrec = $_; $inrec =~ s/=\s*"(.*)"/= '$1'/g; $lineCount++;
if ( $inrec =~ m/^\s*\/\// ) { print OUT "$inrec\n"; $outCount++; print NEW "$inrec\n"; $newCount++; next; } if ($inrec =~ m/^\s*#/ ) { print OUT "$inrec\n"; $outCount++; print NEW "$inrec\n"; $newCount++; next; } if ( $inrec !~ m/^\$(\S+)\s*=\s*[\'|\"](\S+)[\'|\"]/) { print OUT "$inrec\n"; $outCount++; print NEW "$inrec\n"; $newCount++; next; }
$phpname = $1; $wdname = $2;
if ($tags{$phpname}) { $dupTagCount++; $tags{$phpname} .= "\tdup=$wdname:$lineCount"; $duptags{$phpname}++; $commentCount++; $inrec = "//--duplicate-- " . $inrec; } else { $tags{$phpname} = "first=$wdname:$lineCount"; $tagCount++; print NEW "$inrec\n"; $newCount++; } print OUT "$inrec\n"; $outCount++; } close IN; close OUT;
print "..$lineCount lines in $inFile.\n"; print "..$tagCount tags found.\n"; print "..$outCount lines written to $outFile with $commentCount duplicated tags commented out.\n"; print "..$newCount lines written to $newFile with duplicated lines removed.\n"; print "..$dupTagCount duplicate tags found (first=WDTAG:lineno dup=WDTAG:lineno ):\n";
foreach $key (sort keys %duptags) { print "\$$key\t" . $tags{$key} . "\n"; }
which returned the following results Opening testtags-original.txt for analysis. ..1079 lines in testtags-original.txt. ..602 tags found. ..1079 lines written to testtags-commented.txt with 207 duplicated tags commented out. ..872 lines written to testtags.txt with duplicated lines removed. ..207 duplicate tags found (first=WDTAG:lineno dup=WDTAG:lineno ): $VPet first=%VPet%:403 dup=%VPet%:989 $VPetmonth first=%VPetmonth%:404 dup=%VPetmonth%:677 dup=%VPetmonth%:854 dup=%VPetmonth%:990 $WUmaxtemp first=%WUmaxtemp%:135 dup=%WUmaxtemp%:657 dup=%WUmaxtemp%:834 $WUmaxtempr first=%WUmaxtempr%:138 dup=%WUmaxtempr%:659 dup=%WUmaxtempr%:836 $WUmaxtempryr first=%WUmaxtempryr%:140 dup=%WUmaxtempryr%:661 dup=%WUmaxtempryr%:838 $WUmintemp first=%WUmintemp%:136 dup=%WUmintemp%:658 dup=%WUmintemp%:835 $WUmintempr first=%WUmintempr%:139 dup=%WUmintempr%:660 dup=%WUmintempr%:837 $WUmintempryr first=%WUmintempryr%:141 dup=%WUmintempryr%:662 dup=%WUmintempryr%:839 $airdensity first=%airdensity%:653 dup=%airdensity%:830 $apparentsolartempc first=%apparentsolartempc%:131 dup=%apparentsolartempc%:685 dup=%apparentsolartempc%:747 $apparentsolartempf first=%apparentsolartempf%:133 dup=%apparentsolartempf%:684 dup=%apparentsolartempf%:746 $avtempweek first=%avtempweek%:625 dup=%avtempweek%:784 $burntime first=%burntime%:230 dup=%burntime%:708 dup=%burntime%:762 $cddday first=%cddday%:644 dup=%cddday%:817 $cddmonth first=%cddmonth%:645 dup=%cddmonth%:818 $cddyear first=%cddyear%:646 dup=%cddyear%:819 $chandler first=%chandler%:709 dup=%chandler%:763 $changeinday first=%changeinday%:655 dup=%changeinday%:832 $coldestdayonrecord first=%coldestdayonrecord%:627 dup=%coldestdayonrecord%:786 $coldestnightonrecord first=%coldestnightonrecord%:629 dup=%coldestnightonrecord%:788 $dayswithrain first=%dayswithrain%:203 dup=%dayswithrain%:932 $dayswithrainyear first=%dayswithrainyear%:204 dup=%dayswithrainyear%:933 $etcurrentweek first=%etcurrentweek%:680 dup=%etcurrentweek%:858 $firewi first=%FWIfwi%:624 dup=%FWIfwi%:783 $fullmoondate first=%fullmoondate%:65 dup=%fullmoondate%:690 dup=%fullmoondate%:752 $hddday first=%hddday%:641 dup=%hddday%:814 $hddmonth first=%hddmonth%:642 dup=%hddmonth%:815 $hddyear first=%hddyear%:643 dup=%hddyear%:816 $highbaro first=%highbaro%:406 dup=%highbaro%:879 $highbarot first=%highbarot%:407 dup=%highbarot%:881 $highsolaryest first=%highsolaryest%:408 dup=%highsolaryest%:906 $highsolaryesttime first=%highsolaryesttime%:409 dup=%highsolaryesttime%:925 $highuvyest first=%highuvyest%:228 dup=%highuvyest%:913 $highuvyesttime first=%highuvyesttime%:229 dup=%highuvyesttime%:926 $lighteningcountlast12hour first=%lighteningcountlast12hour%:699 dup=%lighteningcountlast12hour%:757 $lighteningcountlast30minutes first=%lighteningcountlast30minutes%:700 dup=%lighteningcountlast30minutes%:758 $lighteningcountlast5minutes first=%lighteningcountlast5minutes%:698 dup=%lighteningcountlast5minutes%:756 $lighteningcountlasthour first=%lighteningcountlasthour%:696 dup=%lighteningcountlasthour%:754 $lighteningcountlastminute first=%lighteningcountlastminute%:697 dup=%lighteningcountlastminute%:755 $lighteningcountlasttime first=%lighteningcountlasttime%:701 dup=%lighteningcountlasttime%:759 $lighteningcountmonth first=%lighteningcountmonth%:702 dup=%lighteningcountmonth%:760 $lighteningcountyear first=%lighteningcountyear%:703 dup=%lighteningcountyear%:761 $maxaverageyest first=%maxaverageyest%:411 dup=%maxaverageyest%:871 dup=%maxaverageyest%:928 $maxaverageyestt first=%maxaverageyestt%:412 dup=%maxaverageyestt%:927 $maxbaroyest first=%maxbaroyest%:416 dup=%maxbaroyest%:564 dup=%maxbaroyest%:883 $maxbaroyestt first=%maxbaroyestt%:417 dup=%maxbaroyestt%:565 dup=%maxbaroyestt%:930 $maxgustyest first=%maxgustyest%:419 dup=%maxgustyest%:554 dup=%maxgustyest%:872 $maxgustyestt first=%maxgustyestt%:420 dup=%maxgustyestt%:555 dup=%maxgustyestt%:929 $maxheatweek first=%maxheatweek%:651 dup=%maxheatweek%:712 $maxsolarfortime first=%maxsolarfortime%:688 dup=%maxsolarfortime%:750 dup=%maxsolarfortime%:857 $maxtempyestt first=%maxtempyestt%:148 dup=%maxtempyestt%:921 $minbaroyest first=%minbaroyest%:566 dup=%minbaroyest%:884 $minbaroyestt first=%minbaroyestt%:567 dup=%minbaroyestt%:931 $minchillweek first=%minchillweek%:648 dup=%minchillweek%:821 $minchillyest first=%minchillyest%:423 dup=%minchillyest%:650 dup=%minchillyest%:825 $minchillyestt first=%minchillyestt%:424 dup=%minchillyestt%:923 $mintempyestt first=%mintempyestt%:150 dup=%mintempyestt%:922 $minwindch first=%minwindch%:425 dup=%minwindch%:647 dup=%minwindch%:820 $minwindcht first=%minwindcht%:426 dup=%minwindcht%:649 dup=%minwindcht%:822 $monthname first=%monthname%:42 dup=%monthname%:91 $monthrn first=%monthrn%:200 dup=%monthrn%:678 dup=%monthrn%:855 $mrecordhighavwindday first=%mrecordhighavwindday%:427 dup=%mrecordhighavwindday%:965 $mrecordhighavwindmonth first=%mrecordhighavwindmonth%:428 dup=%mrecordhighavwindmonth%:966 $mrecordhighbaro first=%mrecordhighbaro%:430 dup=%mrecordhighbaro%:579 $mrecordhighbaroday first=%mrecordhighbaroday%:431 dup=%mrecordhighbaroday%:580 dup=%mrecordhighbaroday%:973 $mrecordhighbaromonth first=%mrecordhighbaromonth%:432 dup=%mrecordhighbaromonth%:581 dup=%mrecordhighbaromonth%:974 $mrecordhighbaroyear first=%mrecordhighbaroyear%:433 dup=%mrecordhighbaroyear%:582 $mrecordhighgustday first=%mrecordhighgustday%:246 dup=%mrecordhighgustday%:969 $mrecordhighgustmonth first=%mrecordhighgustmonth%:434 dup=%mrecordhighgustmonth%:556 dup=%mrecordhighgustmonth%:970 $mrecordhighgustyear first=%mrecordhighgustyear%:435 dup=%mrecordhighgustyear%:557 $mrecordhightemp first=%mrecordhightemp%:436 dup=%mrecordhightemp%:569 dup=%mrecordhightemp%:859 $mrecordhightempday first=%mrecordhightempday%:437 dup=%mrecordhightempday%:570 dup=%mrecordhightempday%:941 $mrecordhightempmonth first=%mrecordhightempmonth%:438 dup=%mrecordhightempmonth%:571 dup=%mrecordhightempmonth%:942 $mrecordhightempyear first=%mrecordhightempyear%:439 dup=%mrecordhightempyear%:572 $mrecordlowbaroday first=%mrecordlowbaroday%:585 dup=%mrecordlowbaroday%:977 $mrecordlowbaromonth first=%mrecordlowbaromonth%:586 dup=%mrecordlowbaromonth%:978 $mrecordlowchill first=%mrecordlowchill%:440 dup=%mrecordlowchill%:863 $mrecordlowchillday first=%mrecordlowchillday%:441 dup=%mrecordlowchillday%:949 $mrecordlowchillmonth first=%mrecordlowchillmonth%:442 dup=%mrecordlowchillmonth%:950 $mrecordlowtemp first=%mrecordlowtemp%:444 dup=%mrecordlowtemp%:574 dup=%mrecordlowtemp%:860 $mrecordlowtempday first=%mrecordlowtempday%:445 dup=%mrecordlowtempday%:575 dup=%mrecordlowtempday%:943 $mrecordlowtempmonth first=%mrecordlowtempmonth%:446 dup=%mrecordlowtempmonth%:576 dup=%mrecordlowtempmonth%:944 $mrecordlowtempyear first=%mrecordlowtempyear%:447 dup=%mrecordlowtempyear%:577 $nextnewmoon first=%nextnewmoon%:61 dup=%nextnewmoon%:691 dup=%nextnewmoon%:753 $raincurrentweek first=%raincurrentweek%:451 dup=%raincurrentweek%:679 dup=%raincurrentweek%:856 $recorddailyrain first=%recorddailyrain%:813 dup=%recorddailyrain%:940 $recordhightemp first=%recordhightemp%:630 dup=%recordhightemp%:789 $recordhightempday first=%recordhightempday%:632 dup=%recordhightempday%:791 $recordhightempmonth first=%recordhightempmonth%:631 dup=%recordhightempmonth%:790 $recordhightempyear first=%recordhightempyear%:633 dup=%recordhightempyear%:792 $recordlowchill first=%recordlowchill%:652 dup=%recordlowchill%:827 $recordlowchillday first=%recordlowchillday%:639 dup=%recordlowchillday%:798 $recordlowchillmonth first=%recordlowchillmonth%:638 dup=%recordlowchillmonth%:797 $recordlowchillyear first=%recordlowchillyear%:640 dup=%recordlowchillyear%:799 $recordlowtemp first=%recordlowtemp%:634 dup=%recordlowtemp%:793 $recordlowtempday first=%recordlowtempday%:636 dup=%recordlowtempday%:795 $recordlowtempmonth first=%recordlowtempmonth%:635 dup=%recordlowtempmonth%:794 $recordlowtempyear first=%recordlowtempyear%:637 dup=%recordlowtempyear%:796 $snowdaysthismonth first=%snowdaysthismonth%:266 dup=%snowdaysthismonth%:675 dup=%snowdaysthismonth%:852 $snowdaysthisyear first=%snowdaysthisyear%:267 dup=%snowdaysthisyear%:676 dup=%snowdaysthisyear%:853 $snowmonthcm first=%snowmonthcm%:256 dup=%snowmonthcm%:670 dup=%snowmonthcm%:848 $snowmonthin first=%snowmonthin.%:253 dup=%snowmonthin.%:665 dup=%snowmonthin.%:843 $snownowcm first=%snownowcm%:263 dup=%snownowcm%:672 dup=%snownowcm%:850 $snownowin first=%snownowin.%:262 dup=%snownowin.%:667 dup=%snownowin.%:845 $snowseasoncm first=%snowseasoncm%:255 dup=%snowseasoncm%:669 dup=%snowseasoncm%:847 $snowseasonin first=%snowseasonin.%:252 dup=%snowseasonin.%:664 dup=%snowseasonin.%:842 $snowtodaycm first=%snowtodaycm%:257 dup=%snowtodaycm%:671 dup=%snowtodaycm%:849 $snowtodayin first=%snowtodayin.%:254 dup=%snowtodayin.%:666 dup=%snowtodayin.%:844 $snowyesterday first=%snowyesterday%:258 dup=%snowyesterday%:674 dup=%snowyesterday%:840 $solarnoon first=%solarnoon%:654 dup=%solarnoon%:831 $sunshinehourstodateday first=%sunshinehourstodateday%:686 dup=%sunshinehourstodateday%:748 dup=%sunshinehourstodateday%:900 $sunshinehourstodatemonth first=%sunshinehourstodatemonth%:687 dup=%sunshinehourstodatemonth%:749 dup=%sunshinehourstodatemonth%:901 $vpconsolebattery first=%vpconsolebattery%:623 dup=%vpconsolebattery%:782 $vpissstatus first=%vpissstatus%:621 dup=%vpissstatus%:780 $vpreception2 first=%vpreception2%:622 dup=%vpreception2%:781 $warmestdayonrecord first=%warmestdayonrecord%:626 dup=%warmestdayonrecord%:785 $warmestnightonrecord first=%warmestnightonrecord%:628 dup=%warmestnightonrecord%:787 $wetbulb first=%wetbulb%:689 dup=%wetbulb%:751 $windruntodatethismonth first=%windruntodatethismonth%:455 dup=%windruntodatethismonth%:983 $windruntodatethisyear first=%windruntodatethisyear%:456 dup=%windruntodatethisyear%:984 $windruntoday first=%windruntoday%:457 dup=%windruntoday%:981 $yearrn first=%yearrn%:201 dup=%yearrn%:869 $yeartodateavwind first=%yeartodateavwind%:877 dup=%yeartodateavwind%:887 $yeartodategstwind first=%yeartodategstwind%:878 dup=%yeartodategstwind%:888 $yesterdayrain first=%yesterdayrain%:211 dup=%yesterdayrain%:870 $yrecordhighavwindday first=%yrecordhighavwindday%:459 dup=%yrecordhighavwindday%:967 $yrecordhighavwindmonth first=%yrecordhighavwindmonth%:460 dup=%yrecordhighavwindmonth%:968 $yrecordhighbaro first=%yrecordhighbaro%:462 dup=%yrecordhighbaro%:599 dup=%yrecordhighbaro%:891 $yrecordhighbaroday first=%yrecordhighbaroday%:463 dup=%yrecordhighbaroday%:600 dup=%yrecordhighbaroday%:975 $yrecordhighbaromonth first=%yrecordhighbaromonth%:464 dup=%yrecordhighbaromonth%:601 dup=%yrecordhighbaromonth%:976 $yrecordhighbaroyear first=%yrecordhighbaroyear%:465 dup=%yrecordhighbaroyear%:602 $yrecordhighgustday first=%yrecordhighgustday%:466 dup=%yrecordhighgustday%:560 dup=%yrecordhighgustday%:971 $yrecordhighgustmonth first=%yrecordhighgustmonth%:467 dup=%yrecordhighgustmonth%:561 dup=%yrecordhighgustmonth%:972 $yrecordhighgustyear first=%yrecordhighgustyear%:468 dup=%yrecordhighgustyear%:562 $yrecordhightemp first=%yrecordhightemp%:469 dup=%yrecordhightemp%:589 dup=%yrecordhightemp%:866 $yrecordhightempday first=%yrecordhightempday%:470 dup=%yrecordhightempday%:590 dup=%yrecordhightempday%:945 $yrecordhightempmonth first=%yrecordhightempmonth%:471 dup=%yrecordhightempmonth%:591 dup=%yrecordhightempmonth%:946 $yrecordhightempyear first=%yrecordhightempyear%:472 dup=%yrecordhightempyear%:592 $yrecordlowbaro first=%yrecordlowbaro%:604 dup=%yrecordlowbaro%:892 $yrecordlowbaroday first=%yrecordlowbaroday%:605 dup=%yrecordlowbaroday%:979 $yrecordlowbaromonth first=%yrecordlowbaromonth%:606 dup=%yrecordlowbaromonth%:980 $yrecordlowchill first=%yrecordlowchill%:473 dup=%yrecordlowchill%:868 $yrecordlowchillday first=%yrecordlowchillday%:474 dup=%yrecordlowchillday%:951 $yrecordlowchillmonth first=%yrecordlowchillmonth%:475 dup=%yrecordlowchillmonth%:952 $yrecordlowtemp first=%yrecordlowtemp%:477 dup=%yrecordlowtemp%:594 dup=%yrecordlowtemp%:867 $yrecordlowtempday first=%yrecordlowtempday%:478 dup=%yrecordlowtempday%:595 dup=%yrecordlowtempday%:947 $yrecordlowtempmonth first=%yrecordlowtempmonth%:479 dup=%yrecordlowtempmonth%:596 dup=%yrecordlowtempmonth%:948 $yrecordlowtempyear first=%yrecordlowtempyear%:480 dup=%yrecordlowtempyear%:597 $yrecordwindgust first=%yrecordwindgust%:481 dup=%yrecordwindgust%:559 dup=%yrecordwindgust%:899
I've attached testtags-original (the 4 combined), testtags-commented (with the duplicated lines commented out), and finally testtags.txt (the new 1.05V1.06 version with no duplicated tags). I'll be adding that to the distributions tonight. Best regards, Ken EDIT: updated with testtags.txt V1.0 6 to support Scott's Alternative Dashboard V4.00 release.
« Last Edit: July 13, 2009, 12:47:34 AM by ktrue »
Logged
Ken True Saratoga WeatherCWOP: CW1792 WeatherUnderground: KCASARAT1 Free weather website PHP scripts and WD website AJAX templates
ktrue
« Reply #1 on: July 12, 2009, 04:46:20 AM » |
Distributions now updated with V1.05 of testtags.txt
Best regards, Ken
Logged
JtwnPaWeather
Johnstown PA Weather
Senior Forecaster
OnlineLocation: Johnstown, PA Station Type: Davis Vantage Pro 2 Plus
Posts: 447 Local Time: Thursday 11:27
« Reply #2 on: July 12, 2009, 05:11:31 AM » |
Just placed the new testtags in place now.
Logged
 Lat: 40.295505 40:17:43.818N Lon: -078.905686 78:54:20.470W
MCHALLIS
Rain Maker
OfflineLocation: Long Beach, WA USA Station Type: Davis VP2+
Posts: 1,997 Local Time: Thursday 11:27
« Reply #3 on: July 12, 2009, 06:31:18 AM » |
Thanks Ken
Logged
jahuff
Weather Guru
OfflineLocation: Northern New Hampshire, USA Station Type: Davis Vantage Pro2 Plus, 1-wire lightning, solar and soil moisture
Posts: 587 Local Time: Thursday 14:27
« Reply #4 on: July 12, 2009, 11:29:49 AM » |
Thanks Ken, this makes it easy to update. John
Logged
HometownZone
Scott
Rain Maker
OfflineLocation: Webster, MN, USA Station Type: Vantage Pro II
Posts: 1,084 Local Time: Thursday 13:27
« Reply #5 on: July 12, 2009, 12:27:45 PM » |
Thanks Ken!! They work very well!
Scott
Logged
Scott www.WebsterWeatherLIVE.comWindows XP Pro (SP3), 4G Ram, QuickCam Pro 9000, Davis Vantage Pro II w/Solar & Heated Rain Catcher, WXSim, 1-Wire: Lightning/UV
Stronghurst
The Local Weather Source
Rain Maker
OfflineLocation: Stronghurst,IL USA Station Type: Davis VP2 +
Posts: 1,685 Local Time: Thursday 13:27
« Reply #6 on: July 12, 2009, 12:43:56 PM » |
Thank you
Mark
Logged
charmed
Junior Forecaster
OfflineLocation: Fredericton, New Brunswick Station Type: Davis VP2+
Posts: 94 Local Time: Thursday 17:27
« Reply #7 on: July 12, 2009, 05:07:06 PM » |
My high temp, UV etc. are not updating I'll have to look into this evening.
Rick
Logged
charmed
Junior Forecaster
« Reply #8 on: July 12, 2009, 05:15:22 PM » |
False alarm I just happened to be viewing just as the sun came out and was waffling on the temp and UV in between testtag updates.
Rick
Logged
wslangerak
Kees
Senior Forecaster
OfflineLocation: Langerak (ZH) - The Netherlands Station Type: TFA Nexus Pro - Win XP on eeePC - WD 10.37P build37
Posts: 499 Local Time: Thursday 20:27
« Reply #9 on: July 12, 2009, 06:07:18 PM » |
Thanks Ken, they work a treat!
Logged
the delicate sound of thunder.....
MCHALLIS
Rain Maker
« Reply #10 on: July 12, 2009, 09:29:43 PM » |
I wish the winds did not have decimal places. I read somewhere that mph wind measurements usually do not need decimals.
$avgspd = '4.5 mph'; // average wind speed (current) $gstspd = '3.0 mph'; // current/gust wind speed $maxgst = '11.0 mph'; // today's maximum wind speed $maxgstt = '12:39 PM'; // time this occurred $maxgsthr = '11.0 mph NNE'; // maximum gust last hour
Wonder why baro has .in instead of in. $baro = '30.050 .in'; // current barometer this one too... $vpstormrain = '0.00 .in'; //Davis VP Storm rain value
Rain has in. and looks OK $dayrn = '0.00 in.'; // today's rain $monthrn = '0.00 in.'; // rain so far this month $yearrn = '0.00 in.'; // rain so far this year
Logged
ktrue
« Reply #11 on: July 12, 2009, 10:41:28 PM » |
Just out.. V1.06 of testtags.txt to support Scott's Alternative Dashboard V4.00.
Download a new distribution or just use the attached V1.06 testtags.txt to replace your existing one.
Best regards, Ken
Logged
ktrue
« Reply #12 on: July 12, 2009, 11:24:22 PM » |
I've noticed those too, Mike -- it's why I tend to use strip_units(), then sprintf() to set the decimals I want, and use the $uom... strings in the dashboard/gizmo/Settings.php to make units displays uniform  Best regards, Ken
Logged
JtwnPaWeather
Senior Forecaster
« Reply #13 on: July 12, 2009, 11:34:36 PM » |
Thanks for the updated 1.05 ken you are the man, and so are the others.
Logged
MCHALLIS
Rain Maker
« Reply #14 on: July 12, 2009, 11:55:03 PM » |
I've noticed those too, Mike -- it's why I tend to use strip_units(), then sprintf() to set the decimals I want, and use the $uom... strings in the dashboard/gizmo/Settings.php to make units displays uniform  Best regards, Ken Works for me, thanks
Logged
