cloudy
Author Topic: Units in tags causing problems? Here's how to remove them easily.  (Read 9261 times)
Offline niko
  • syzygy
  • Global Moderator
  • Northern California, U.S.A.
Special characters like the degree symbol included in some tags can cause problems with website coding, and any units need to be stripped out before a value can be used in a calculation. Fortunately WD has a setting to eliminate the units from all tags giving the user complete control over the presentation of values.
Control Panel > Web Files/Web Page > Custom webpage setup
Uncheck the checkbox for "Include the units used"
Offline JaxWeather
  • Bob
  • Global Moderator
  • WML Station: WD00007
  • Jacksonville, Fl. USA
    • JaxWeather.net
Re: Units in tags causing problems? Here's how to remove them easily.
« Reply #1 on: June 24, 2009, 03:50:24 PM »
Won't that also affect existing uses of those tags requiring recoding everything that uses them previously?
Offline niko
  • syzygy
  • Global Moderator
« Reply #2 on: June 24, 2009, 04:16:52 PM »
That's correct Bob.
