$RSS_URL = 'http://volcano.wr.usgs.gov/cvo/current_updates.php';
$RSS_URL = 'http://volcanoes.usgs.gov/cvo/current_updates.php';
Source: <a href="http://volcano.wr.usgs.gov/cvo/current_updates.php" title="U.S. Geological Survey - Cascade Range Current Update" target="_blank">Cascade Range Current Update</a>
Source: <a href="http://volcanoes.usgs.gov/cvo/current_updates.php" title="U.S. Geological Survey - Cascade Range Current Update" target="_blank">Cascade Range Current Update</a>
Mike:i just noticed that the wxvolcano-ak script is not returning a conditions report despite the fact that one exists in volcano-current-ak.txt. I'd appreciate any help.www.scoblic.com/weather
Keep in mind I've only been playing with this for an hour. It's possible Mike coded the volcano differently based on the website, but your cache file is not formatted the same as mine. There is a link on the page that points to a "cleaner" text version versus the one your grabbing now that is embedded in the webpage. Maybe try pointing your cache file to this URL and see if it parses okay.http://www.avo.alaska.edu/activity/print_report.php?output=screen&id=3982&type=statusfor theCLEVELAND VOLCANO (CAVW #1101-24-)52°49'20" N 169°56'42" W, Summit Elevation 5676 ft (1730 m)Current Volcano Alert Level: WATCHCurrent Aviation Color Code: ORANGE
Page could not be found. -- www.avo.alaska.edu/activity/avoreport.php%20title=We're sorry. It seems that the page you requested has moved or does not exist. If you typed in a web address by hand, please check that the spelling of the page you requested is correct. If you are unsure, please try one of the following links:
It appears the link for the Cleveland volcano is returning an not found error:The link for Mt. Redoubt seems to be working, so I can only guess the format of the page has changed and the parser is not able to find the information.
Suddenly! Cleveland is working! Don't know what I did if anything!
