cloudy
Author Topic: Volcano Conditions PHP Script  (Read 7993 times)
Offline Silversword
  • --Stan Y.
  • Maui, Hawaii
    • Up Country Maui Weather
Re: Volcano Conditions PHP Script
« Reply #15 on: June 29, 2009, 03:35:46 PM »
Hi again,
Took a look at the volcano-current-hi.txt file on the host server and got the attached file. Guess that something is still amiss that the script may not point to it..Will check on that later this evening when I get back home.
--Stan Y.
   Maui, Hawaii
WD 10.37r Bld 00
WDL 6.05
Dell Optiplex GX280-Intel Pentium 4 CPU 3.00GHz, 4 GB RAM
Webcam: Panasonic BL-C1A
Offline MCHALLIS
  • Long Beach, WA USA
    • Weather for Long Beach, WA USA
« Reply #16 on: June 29, 2009, 03:45:36 PM »
It needed changes to the preg_match
I have it working.
I have attached a copy. Also release a new 1.01 zip that includes it.
« Last Edit: June 29, 2009, 04:16:05 PM by MCHALLIS »
Offline Silversword
  • --Stan Y.
  • Maui, Hawaii
« Reply #17 on: June 29, 2009, 08:03:03 PM »
Hi Mike,
Thank you for the update and editing the script.
Got it working at www.dwayneyamato.com/wx/wxvolcano-hi.php.
There is another active site on the same mountain, Mauna Loa, called Puu O'O vent.  I wonder if I should try to make another page for it also.  If time permits, I will try that too.
Again thanks for your support for this project.
--Stan Y.
   Maui, Hawaii
WD 10.37r Bld 00
WDL 6.05
Offline jjmcnelly
  • Napavine, WA
    • Cedar Ridge Weather Station, Napavine WA 98565
Re: Volcano Conditions PHP Script *Updated*
« Reply #18 on: October 12, 2009, 04:00:26 AM »
For some reason it says the report is not available....
http://www.napavineweather.info/wxvolcano-wa.php
James
Update:  Here is a copy of the current cache file attached
« Last Edit: October 13, 2009, 02:13:58 AM by jjmcnelly »
Offline ALITTLEweird1
  • Mark
  • Snoqualmie,WA
    • Snoqualmie Weather
« Reply #19 on: October 12, 2009, 04:21:14 PM »
mine is saying the samething. It looks like its a problem at the USGS.
"Nature can do without man, but man cannot do without nature."
Davis VP2 + 1-Wire Solar + 1-wire Lightning + 1-Wire UV + Logitech Webcam
Offline jjmcnelly
  • Napavine, WA
Re: Volcano Conditions PHP Script *updated*
« Reply #20 on: October 13, 2009, 02:18:18 AM »
added attachment FYI
Offline MCHALLIS
« Reply #21 on: October 13, 2009, 04:30:57 AM »
They changed their HTML a bit. I have the fix:
Change:
Code: [Select]
   preg_match('|<strong>CASCADES VOLCANO OBSERVATORY(.*)changes in alert level as warranted.|Us', $volcanodata, $betweenspan);
   $string .= $betweenspan[1];
    if ($string == '') {
           $string  = 'Mount St. Helens Volcano Update unavailable, please try later.';
    } else {
           $string = "<strong>CASCADES VOLCANO OBSERVATORY$string"."changes in alert level as warranted<br /><br />";
   $string = str_replace('/Back to top/', '', $string);
   $string = preg_replace("|<br />\r\n<br />\r\n<br />\r\n<br />\r\n|Us", '<br />', $string);
   $string= strip_tags($string, '<p><h3><br><strong>');
to:
Code: [Select]
   preg_match('|<b>CASCADES VOLCANO OBSERVATORY WEEKLY UPDATE</b>(.*)</cascade_update>|Us', $volcanodata, $betweenspan);
    } else {
           $string = "<b>CASCADES VOLCANO OBSERVATORY</b><br />$string<br /><br />";
   $string = strip_tags($string, '<b><br>');
Offline MCHALLIS
« Reply #22 on: October 13, 2009, 04:34:59 AM »
Version: 1.02 - 12-Oct-2009 - wxvolcano-wa.php fix for missing conditions text after USGS changed their HTML.
Offline Silversword
  • --Stan Y.
  • Maui, Hawaii
« Reply #23 on: October 13, 2009, 03:41:57 PM »
Hi All,
My Volcano page seems to be working okay for the moment without the code modifications.  Guess different areas do different things.
--Stan Y.
   Maui, Hawaii
WD 10.37r Bld 00
WDL 6.05
Offline i_fiorentino
  • 160 mls Carmignano (Po), Tuscany, Italy
    • Meteocarmignano.it
« Reply #24 on: October 14, 2009, 11:45:31 AM »
Hi Mike,
could you add Stromboli and/or Etna in italy??
Thank you very much,
Alessandro
Offline MCHALLIS
« Reply #25 on: October 14, 2009, 01:39:24 PM »
Hi Mike,
Alessandro
Do you have a URL to those volcano information pages?
« Reply #26 on: October 14, 2009, 03:29:12 PM »
Hi Mike,
what kind of information do you need to?
If you need to have general information it's here: http://www.ct.ingv.it/Default.asp
If not, please reply to this post.
Thanks again,
Alessandro
Offline niko
  • syzygy
  • Global Moderator
  • Northern California, U.S.A.
« Reply #27 on: October 14, 2009, 03:44:37 PM »
Alessandro
Mike needs a link to a page like this one for the US that gives links to updated current information about the volcanoes.
« Reply #28 on: October 14, 2009, 05:23:19 PM »
I knew.
Unfortunately it doesn't exist in italy a similar resource.
Alessandro
Offline lddaly
  • Plano, Texas - USA
  • Plano, TX - USA
    • Plano, TX Weather
« Reply #29 on: April 07, 2010, 03:35:46 AM »
If you are using the wxvolcano-ak.php page, your RSS URL may be out of date. The following change worked for me:
Code: [Select]
$RSS_URL = 'http://www.avo.alaska.edu/release.php';
