cloudy
Author Topic: Initial Setup for Rainwise WS2000  (Read 854 times)
Offline headhog
« on: June 09, 2009, 11:27:39 PM »
How do you set up Weather Display to connect to the WS 2000 computer interface?
I have a serial to USB adapter connected to my MAC.
Online Weather Display
Re: Initial Setup for Rainwise WS2000
« Reply #1 on: June 09, 2009, 11:52:38 PM »
in a terminal window
type
ls /dev/tty.*
and see if the driver shows up
then enter that as the port driver to use in the com port setup in WD (if it does not show up when you click to list the devices)
Offline mfd38
  • Massachusetts
    • Medfield, MA Weather
« Reply #2 on: June 10, 2009, 12:06:02 AM »
Hi headhog,
If you have no luck with what Windy suggests, you more than likely will need to get a Keyspan USA-19HS adapter. That was the only adapter that would work for me, and apparently for many others as well. It does cost a little more than most adapters but is is worth it. Good luck,
Paul
Offline headhog
« Reply #3 on: June 10, 2009, 09:38:45 PM »
Thanks for the replys.
The result from Is /dev/tty.* is:  -bash: Is: command not found
BobMacPro:~ robertstrasser$
Thanks for the tip on the Keyspan adapter.
Bob
Offline kernowyon
  • Cornwall,UK
« Reply #4 on: June 10, 2009, 09:55:52 PM »
Bob
Not a Mac user (I am a Linux guy), but the command will be lower case L rather than upper case I at the start (i.e ls). Not easy to tell with some fonts I know.
Mark
