That is a great question. I know I am getting confused, so I am sure readers of this thread might be scratching their heads. I’ll try and set the stage and provide the details you requested. Here goes…
There are two computers, A and B, on a local network. They are connected to the internet via a router connected to a single cable modem. The cable modem has a single IP address. In this case, 72.192.XXX.YYY. The young girl's comments reminded me each of the places in an IP address, i.e., separated by the period (.), is an octet. See below
Computer A is running WD and will eventually feed data to a test website Eketahuna Weather. Little else is opening ftp connections other than infrequent use of FilleZilla or when WD decides to spontaneously upload something with the Main Internet Switch OFF (discussed below). See [FZ Upload Log Extract.txt](http://beetlecat.net/posts/FZ Upload Log Extract.txt). Note the sequence of server disconnects.
Computer B is running WD and is feeding data to another website which I hope will someday not be in test mode. This site is SuffieldWeather.com. This computer is ftping via the normal WD ftp client and Clientraw Realtime ftp. Since it is in test mode, just about everything is set to upload every five minutes. Whatever ftp client WD uses to upload to Weather Underground is also active and uploading every five minutes.
At least one instance of GRLevel3 is uploading to the website. In addition, WASP2 and NexStorm are primed to begin uploading to the website if and when I can get out of test mode and have a stable installation.
When Computer B is active ftping, strange things happen as seen from Computer A, which is being used to create this post. See [FZ Log showing disconnect.txt](http://beetlecat.net/posts/FZ Log showing disconnect.txt). Note the errors and disconnects.
For an extract covering the time of the post of the Computer B FTP Error Log, see
[Computer B FTP Error Log Extract.txt](http://beetlecat.net/posts/Computer B FTP Error Log Extract.txt).
For an extract of Computer B’s Clientraw FTP log, see [Computer B Realtime Cleintraw FTP Log.txt](http://beetlecat.net/posts/Computer B Realtime Cleintraw FTP Log.txt).
The Main Internet Switch on Computer A has always remained OFF. However, there are WD agenda items that apparently fail to check the switch setting and spontaneously upload. See [Computer A SW OFF FTP ERR Log.txt](http://beetlecat.net/postsComputer A SW OFF FTP ERR Log.txt)
NOTE: Windy addressed the above and the issue is being resolved. I missed his reply. Sorry.
To further compound the matter, it is remotely possible there is something strange going on with the cable modem. For this reason, my ISP, has been working with me to track it down. That is the reason for mentioning the new cable modem. See Reply # 37, specifically:
I am trying to run checks on the router with some new software from Cisco, and I just updated the router's firmware to the most recent release. A different cable modem is being sent to me for testing by my ISP, COX. COX has been monitoring the number of resyncs the present modem is doing and found them on the high side. In addition, I am monitoring the number of internet connection losses with LELA running on the AVG Free system.
The history and rationale for firing up two test systems may be understood by checking out the Abnormal Exit thread. There are other posts scattered around the forums, but these seem to wind up in WD Questions.
I apologize that this is so convoluted. What I thought was a simple question regarding an ftp error message is leading to what might be important in understanding several problems and pitfalls
