cloudy
Author Topic: Boltek driver question  (Read 2357 times)
Offline krekel
  • Assen, Netherlands
    • Weerstation Marsdijk Assen
« on: May 20, 2009, 06:53:39 PM »
Hello,
I hope someone can help me out
I just got the Boltek pci stormtracker card with Nexstorm software.
My system is Win Vista 64 bit.
I installed the 64 bit driver from the Boltek webpage but it won`t work.
First I installed the Nexstorm software and second the Boltek pci driver.
When I start the Nexstorm software I got an error message that the driver isn`t found.
It says: WDAPI921.dll can`t be found. reinstall!
I did that several times. No luck.
I hope someone can help.
Re: Boltek driver question
« Reply #1 on: May 20, 2009, 07:03:28 PM »
try a pc reboot maybe?
Offline krekel
« Reply #2 on: May 20, 2009, 07:09:39 PM »
Did that several times. Won`t work.
Reinstalled the driver and the nexstorm software. Same problem.
« Reply #3 on: May 20, 2009, 07:24:46 PM »
i know that with windows 2000 it took a few hoops to jump through to get the driver to work
try copying the dll file to where nextorm is installed and to c:\winnt\system32\ or similar
Offline krekel
« Reply #4 on: May 20, 2009, 07:56:18 PM »
tried that but it still won`t work.
Damn. must I go back to Win XP?
Offline niko
  • syzygy
  • Global Moderator
  • Northern California, U.S.A.
« Reply #5 on: May 20, 2009, 08:00:23 PM »
Have you tried asking astrogenix/nexstorm?
Offline krekel
« Reply #6 on: May 20, 2009, 08:21:32 PM »
No, I asked it now on their forum.
When somebody has or recognize this same problem, please reply.
Also mailed Boltek.
Offline krekel
« Reply #7 on: May 20, 2009, 08:22:38 PM »
Does anyone got this to work on Win Vista 64 bit?
Offline andro700
  • Chuck
  • Watford City, North Dakota
    • Chuck's Weather Page
« Reply #8 on: May 20, 2009, 08:27:46 PM »
I know this is a long shot I have seen where you set it to run as a administrator sometimes fixes the issue.
Chuck
Offline MesquiteWx
  • Nick
  • Mesquite Weather Network
  • Mesquite, Texas
« Reply #9 on: May 21, 2009, 03:12:13 AM »
Trying installing it and running in compatibility mode?
Offline Budgie
  • Martin
  • Global Moderator
  • WML Station: WD00934 CWOP: CW7959
  • Isle of Lewis, Scotland
    • Hebrides-Weather
« Reply #10 on: May 21, 2009, 06:53:41 AM »
Which driver have you been trying to install?
You say in the first post:
Quote
But on the Boltek Website it says:
Quote
This installation program will copy the new 64 bit StormPCI_DLL.dll file over top of NexStorm's 32 bit version.  To manually copy the file the 64 bit DLL can also be found in "C:\Program Files (x86)\Boltek\StormTracker PCI Driver 64 bit".
Offline Budgie
  • Martin
  • Global Moderator
    • Hebrides-Weather
« Reply #11 on: May 21, 2009, 09:24:55 AM »
Scrub the above.
I see you have Relko on the case on the Astrogenics forum, hope he gets you sorted.
For others, the current Nexstorm program won't run on Vista 64 as Relko wasn't informed that Boltek had released a new driver for it.
So he's working on it.  :wink:
Offline krekel
« Reply #12 on: May 21, 2009, 04:08:55 PM »
Hello all,
Thanks for the advises. Did a lot but nothing worked.
As Budgie said, I have good support from Astrogenic (Relko) an Boltek ( Robert) and they promised to have very shortly a solution for Vista 64 bit. Both are working on it.
So I`m still waiting.
Thanks again.
krekel
« Last Edit: May 21, 2009, 08:35:31 PM by krekel »
Offline Marklin
  • Wawa, Ontario Canada
    • Wawaweather.net
« Reply #13 on: May 28, 2009, 04:48:01 PM »
Hopefully a solution is not too far away, as I am in a similar situation also.
I am unable to install the driver period since the install program for the 64-Bit driver thinks I have a computer which does not qualify and I am currently running Windows 2003 Server Enterprise in 64 Bit mode.
Will have to wait an see.
Matthew Romer
Wawa Ontario, Canada
Offline Marklin
    • Wawaweather.net
« Reply #14 on: June 01, 2009, 02:49:35 PM »
I have just received a replay from Robert Boll that a update to the Boltek StormTracker PCI Driver (64 bit) has be created and this now solves my problem of trying to install the Boltek StormTracker PCI Driver (64 bit) on a Windows 2003 Server R2 Enterprise x64 Edition system.
Matthew Romer
