cloudy
Author Topic: webcam  (Read 7328 times)
Offline Andretti
  • Poland, silesia, Zabrze
    • ASM Poland - Zabrze
Re: webcam
« Reply #30 on: December 24, 2009, 10:30:08 PM »
"connecting with multimedia" .... then "OK" - but still black :(
no pictures from camera
Offline Budmn8
  • Eastern Iowa
    • Sandhill Weather
Re: webcam
« Reply #31 on: December 24, 2009, 10:32:30 PM »
I hate to keep doing this to you guys but I can't see the webcam from my side of the router.
I have switched to windy's webcamcapture program.
www.thanko.info/webcam_test.php
 Still no luck Tim.  FF wants  me to download a plugin
IE acts like it wants to load but doesn't
Brad
Offline Tim Hanko
  • Grand Rapids, Michigan, USA
    • Walker, MI Weather
Re: webcam
« Reply #32 on: December 24, 2009, 10:47:31 PM »
It would be black as it is night time here and I have a crappy camera.
I wonder what the bleep I am doing wrong. Port is open. I can open the stream on the local network. IP in the code is the external IP from whatismyip.com. Port is correct in the code.
Code: [Select]
<OBJECT ID="MediaPlayer1" width=640 height=480
    classid="CLSID:22D6F312-B0F6-11D0-94AB-0080C74C7E95"
    codebase=
    "http://activex.microsoft.com/activex/controls/mplayer/en/nsmp2inf.cab#Version=5,1,52,701"
        standby="Loading Microsoft® Windows® Media Player components..."
        type="application/x-oleobject">
  <PARAM NAME="FileName" VALUE="mms://ipaddress:8080">
  <PARAM NAME="ShowStatusBar" VALUE="True">
  <PARAM NAME="ShowPositionControls" VALUE="False">
  <PARAM NAME="ShowTracker" VALUE="False">
  <PARAM name=ShowControls VALUE="True">
  <EMBED type="application/x-mplayer2"
    pluginspage = "http://www.microsoft.com/Windows/MediaPlayer/"
    src="mms://ipaddress:8080"
    name="MediaPlayer1"
    width="640"
    height="480"
    ShowStatusBar="True"
    ShowPositionControls="False" ShowTracker="False" ShowControls="True">
  </EMBED>
</OBJECT>
« Last Edit: December 24, 2009, 10:49:30 PM by Tim Hanko »
Offline Budmn8
  • Eastern Iowa
    • Sandhill Weather
Re: webcam
« Reply #33 on: December 24, 2009, 10:54:28 PM »
Offline Tim Hanko
Re: webcam
« Reply #34 on: December 25, 2009, 12:15:42 AM »
Looks like the hole in the firewall was not there. Wonder how that disappeared.
www.thanko.info/webcam.php
Try again, please. Thanks for all the help...
Offline Budmn8
  • Eastern Iowa
    • Sandhill Weather
Re: webcam
« Reply #35 on: December 25, 2009, 03:00:17 AM »
www.thanko.info/webcam.php  works in FF  But the other  link doesn't play.    It loads but when I hit play nothing happens
Brad
Offline CNYWeather
  • Professional Trophymaker!
  • Rome, New York
    • CNYWeather.com
Re: webcam
« Reply #36 on: December 25, 2009, 12:13:57 PM »
Code: [Select]
    src="mms://75.48.120.108:8080"
Should be http://75.48.xxx   etc if I'm not mistaking
Tony
CNYWeather.com
CWOP: CW2352
WeatherUnderground: KNYWESTM1
http://www.CNYWeather.com
I Make Trophies Too!
http://www.speedyawards.com
Offline weatherbee
  • Sherman, Ct.
    • http://www.shermanctweather.com
Re: webcam
« Reply #37 on: December 25, 2009, 01:04:02 PM »
http://www.thanko.info/webcam.php is working for me.  I'm using IE8.
Sony Pentium 4, 1.6 GHZ,512 MB Ram, Windows XP Pro, SP2
Offline Andretti
Re: webcam
« Reply #38 on: December 25, 2009, 04:18:11 PM »
For my working to - in FF @ 12/25/2009 ~ 15:00 PM on webcam
Offline Tim Hanko
Re: webcam
« Reply #39 on: December 26, 2009, 01:12:31 AM »
I updated the flash file. Can someone verify if that gets rid of the popup issue?
Offline niko
  • syzygy
  • Global Moderator
  • Northern California, U.S.A.
Re: webcam
« Reply #40 on: December 26, 2009, 01:19:04 AM »
Big blue rectangle with Webcam offline, that's in IE7.
Offline kernowyon
  • Cornwall,UK
Re: webcam
« Reply #41 on: December 26, 2009, 09:06:58 AM »
Same in Firefox on my Linux system.
Offline NorCal Dan
  • -= Dan =-
  • Marysville, California
    • Skype @ KJ6RGX
    • Traveling RV Weather
Re: webcam
« Reply #42 on: December 26, 2009, 08:32:53 PM »
Might want to try cleaning up the errors on the page first...
Quote
Validation Output:  12 Errors
   1. Error Line 453, Column 13: Attribute "src" exists, but can not be used for this element.
         <embed src="webcamXP.swf?webcam=http://75.48.120.108:8080/cam_1.jpg&amp;refresh
Offline Tim Hanko
Re: webcam
« Reply #43 on: December 27, 2009, 01:28:35 AM »
Someone want to remote in and fix it for me? I have apparently lost my touch. :)
Offline Budmn8
  • Eastern Iowa
    • Sandhill Weather
Re: webcam
« Reply #44 on: December 27, 2009, 01:50:04 AM »
 Tim I know its night but this link seams to be working fine for me
Brad
