Author Topic: Wanting to replace weather station (updated)  (Read 12388 times)
Offline K8SWR
« on: May 08, 2009, 12:42:36 PM »
I currently have a Lacrosse  WS-2310 weather station, and it's getting wore out the Sun has bleached the parts etc..
I'm looking for a new one,
I don't care for the wind fan or the teeter totter Rain gauge, and the fact that it runs of a serial port rather then usb,
I have looked at the Zephyr PWS-1000TD or the Model TP1080WC by Tycon Power Systems
Does anyone have any input on these...
« Last Edit: June 09, 2009, 02:16:30 AM by K8SWR »
Offline NorCal Dan
  • -= Dan =-
  • Marysville, California
    • Skype @ KJ6RGX
    • Traveling RV Weather
Re: Wanting to replace weather station
« Reply #1 on: May 08, 2009, 02:50:38 PM »
Davis VP2 (with serial datalogger) is a good choice...anything else is a compromise.
« Last Edit: May 08, 2009, 08:34:16 PM by NorCal Dan »
Offline niko
  • syzygy
  • Northern California, U.S.A.
« Reply #2 on: May 08, 2009, 02:55:30 PM »
Don't knock old time serial, it's still a very (IMHO the most) reliable way to connect continually communicating device like a weather station. Sounds like you've had a weather station for a long time so if you do have a serious ongoing interest I'll second Dan's suggestion, it's time to get a Davis VP2 (with a serial interface).
Offline K8SWR
« Reply #3 on: May 09, 2009, 09:22:04 AM »
The Davis VP2 is nice but I can't afford one of those right now..
Whats the next Best thing ??
Offline casacota
  • Pyrenees / Catalonia
    • Observatori Meteoroḷgic de Sant Martí de Canals
« Reply #4 on: May 09, 2009, 10:34:48 AM »
I would say: Davis. If you can't afford it (that is also my case) there are on the internet sites where you can buy replacements for the external sensors from the WS-2300, very cheap. Also, you can replace the anemometer with a cup one. I did replace almost everything and that works: http://www.nouveauxobjets.com/pieces_detachees.php
Online jbrooks987
  • Jim
  • Hays, KS
    • Hays, KS Weather
« Reply #5 on: May 09, 2009, 02:17:16 PM »
We've done this argument before - but I'd suggest a Peet Bros. Weather station.  Not quite as steep as the Davis, and they do require a serial port (or usb to serial adapter/driver set).  Mine's been working great for a number of years.
Offline K8SWR
« Reply #6 on: May 09, 2009, 03:40:49 PM »
Well my Lacrosse has been a decent unit and might still work I just know the  sensor fell off the building and was laying in water so I dried it out but haven't tried it, Serial port is fine but I only have one om my current computer and have to use 2 one for my TNC and the other for the weather station,
I was going to buy just the sensor and the fan unit but that was 1/2 of this other unit...
Offline aardvark
  • I am perfectly calm,ready to hear your opinion
  • Des Moines, Iowa, USA
    • Des Moines, Iowa Weather
« Reply #7 on: May 09, 2009, 09:46:22 PM »
I would go with the Davis with the 24 hr Fars and wireless .    Although WD does interface with some pretty fancy units out there.  If I had 30 more years and a lot more funds, I would like to try one of those ultrasonic units...   :wink:
Davis has good after the sale warranty.. they do stand behind their product and that means a lot.  Kind of like buying a good car with crappy maintainence service afterward .. you want the best, Davis so far stands behind all of their products including their discontinued ones as well.. now that is better than Microsoft.
VP2, Daytime Fars, Solar/UV; Soil station; extra temp/humid station; extra temp stations; Windows 7, 8G Ram , 1TB drive/external and Windows xp for weather data.
Offline niko
  • syzygy
« Reply #8 on: May 09, 2009, 11:11:13 PM »
I think we've also done this argument before Jim, but how do you conclude that Peet is less expensive than Davis? Peet doesn't do wireless so the closest comp would appear to be a cabled VP2 + weatherlink logger which is about $450 at Ambient and others. Can a 2100 with the optional ext humidity, optional shelter, and optional rain gauge (and I'll give you a pass for indoor humidity) be had for $450?
Online jbrooks987
  • Jim
  • Hays, KS
    • Hays, KS Weather
« Reply #9 on: May 09, 2009, 11:36:27 PM »
Probably because I haven't checked Davis prices in a while.   :oops:
Yes, they are a good station.  But I think that the peet is in many ways just as good.  :)
Offline niko
  • syzygy
« Reply #10 on: May 10, 2009, 12:34:23 AM »
Agreed, most users seem very happy with the Peet.
Offline K8SWR
« Reply #11 on: May 10, 2009, 11:51:18 PM »
Well I think for now I'm going to buy a new sensor and save for the wind fan,
Thanks For all the help...
Offline Budgie
  • Martin
  • WML Station: WD00934 CWOP: CW7959
  • Isle of Lewis, Scotland
    • Hebrides-Weather
« Reply #12 on: May 11, 2009, 09:13:00 AM »
If you're going for the new anemometer then try to get the cup type that's now fitted to the WS2350, its product ref is TX20 and comes in at $36.75. This works much better then the fan type and is only a $4 more.  :wink:
Offline K8SWR
« Reply #13 on: June 09, 2009, 02:16:04 AM »
Ok well I replaced the parts on my Lacrosse for now and want to mount all my components on a pole,  Rain gauge, temp/humidity sensor and wind sensor,    is this a good idea or should i mount the temp sensor out of direct sunlight??
Re: Wanting to replace weather station (updated)
« Reply #14 on: June 09, 2009, 02:34:42 AM »
its best to put the temp/hum sensor into a instrument shelter
there are threads on how to build one
