Weather-Watch.com
September 02, 2010, 05:43:40 PM *
Welcome, Guest. Please login or register.
Did you miss your activation email?
Login with username, password and session length
Members: 8,509  Posts: 362,030  Topics: 40,113
Please welcome lawrencerebeiro, our newest member.
Latest versions: WD - 10.37P  WDL - 6.05  MML - 1.03
 News:
Check out the new FAQs (Frequently Asked Questions) board for a growing list of hints, tips and diagnostic suggestions.
  Advanced Search
   Home   Bug Tracker Photo Gallery Wiki Chat Calendar Search Login Register Help
Pages: 1 ... 11 12 [13] 14 15 ... 30
  Print  |  « previous  |  next »  |  Go Down
Author Topic: Cloud Height Graphic v2.0  (Read 47249 times)
0 Members and 4 Guests are viewing this topic.
Meerkat
Rainer
Weather Guru
Offline Offline
Station Type: OS WMR200+UV
Local Time: Thursday 20:43
WD v10.37P build 28, Win 7, HP 2 Core 4GB, 7hr UPS
WWW
« Reply #180 on: May 08, 2009, 02:45:10 PM »
Do you ever get that feeling where you wish you never started something?  Embarassed
Yeah, especially when you wanted something to be perfect and then
it turns out that there are different stokes for different folks.
Logged
Cheers,
Rainer
Bashewa Script Collection
Script download links always available on the first page of my threads
Bashy
Guest
« Reply #181 on: May 08, 2009, 02:58:17 PM »
Yeah, i know what you mean, I made some new wind rose graphics that took ages to get
right for what i wanted then  before i knew it i had PMs and posts asking to change them
to suit there sites and so on... i didnt mind so much but i didnt really know what i was doing
so it took a lot longer than it would with someone whos savvy with graphics...
Still, its a great script that Rainers made and has supported it well, I just switched on
the seasons, i love the images and im very grateful...
I remember seeing something similar that someone had made loads of header images to suit
his current weather conditions, loads of images were used.... Smile
« Last Edit: May 08, 2009, 06:51:11 PM by Bashy » Logged
Zalmor
Weather Guru
Offline Offline
Station Type: Davis Vantage Pro 2+ Wireless w/FARS, Rain heater, Soil, Boltek-PCI, WXSIM
Local Time: Thursday 14:43
WWW
« Reply #182 on: May 08, 2009, 03:54:56 PM »
Slight problem here when trying http://southerin-ny.org/cloud-base.php?uom=E&html=1&test=3 or http://southerin-ny.org/cloud-base.php?uom=E&html=0&test=3
Shows:
Code:
Warning: imagealphablending(): supplied argument is not a valid Image resource in /virtual/users/e14016-14028/web/cloud-base.php on line 839
Warning: imagesavealpha(): supplied argument is not a valid Image resource in /virtual/users/e14016-14028/web/cloud-base.php on line 840
All the other tests 1,2,4,5 work correctly.  d'oh!
Using version 1.9, unless I botched up something here once again.
Logged
Michael A
Windows XP Pro SP3, Pentium D 2.80GHz 3GB RAM, Quickcam Pro 4000, APC, VirtualVP, and ZAES
JtwnPaWeather
Johnstown PA Weather
Senior Forecaster
Online Online
Station Type: Davis Vantage Pro 2 Plus
Local Time: Thursday 11:43
WWW
« Reply #183 on: May 08, 2009, 04:08:32 PM »
Thanks Meerkat that fixed it.
Logged
Lat:  40.295505  40:17:43.818N
Lon:  -078.905686  78:54:20.470W
Meerkat
Rainer
Weather Guru
Offline Offline
WWW
« Reply #184 on: May 08, 2009, 07:58:52 PM »
Shows:
Code:
Hi Zalmor,
Sorry botched up again ... was a copy and paste problem from windsock code to moon code without the necessary changes made.
It only happens when you're not displaying the windsock
Grab the update below.
Last edit: Also fixed overflow of cloud height text into conditions when cloud is very low or it's misty.
* cloud-base-update.zip (18.21 KB - downloaded 51 times.)
« Last Edit: May 08, 2009, 11:58:43 PM by Meerkat » Logged
Cheers,
Rainer
Zalmor
Weather Guru
Offline Offline
WWW
« Reply #185 on: May 09, 2009, 03:06:01 AM »
That did it, thanks  Very Happy
Logged
Michael A
Meerkat
Rainer
Weather Guru
Offline Offline
WWW
« Reply #186 on: May 09, 2009, 06:54:18 PM »
There have been a couple of problems with
the OZZ METARs which I have corrected.
I've also made the changes to the METAR DECODER
which will report the OZZ METARs correctly.
Last edit: Updated yet again ... found another bug ... grab below.
* cloud-base-update.zip (18.23 KB - downloaded 35 times.)
« Last Edit: May 09, 2009, 11:15:50 PM by Meerkat » Logged
Cheers,
Rainer
vk2him
Senior Forecaster
Offline Offline
Station Type: La Crosse 2307
Local Time: Friday 04:43
WWW
« Reply #187 on: May 09, 2009, 09:36:33 PM »
The new code is working great Rainer, many thanks!!
Ian
Logged
Meerkat
Rainer
Weather Guru
Offline Offline
WWW
« Reply #188 on: May 09, 2009, 10:46:28 PM »
Ian
Sorry, found another bug in the OZZ METARs.
* cloud-base-update.zip (18.23 KB - downloaded 48 times.)
Logged
Cheers,
Rainer
JohnZ
Junior Watcher
Offline Offline
Station Type: La Crosse Technology WS2315/2308 with Radiation Shield
Local Time: Thursday 21:43
WWW
« Reply #189 on: May 12, 2009, 11:25:14 AM »
Hello guys, and congratulations for your great work here Smile
Unfortunately, I can't make this script to work Sad I have tried almost any possible way but the result I get always is this:
http://www.meteokav.gr/cloud-base.php
clientraw files are here
http://www.meteokav.gr/wdlive/clientraw.txt
http://www.meteokav.gr/wdlive/clientrawextra.txt
Weather Station with Ajax Script here
http://www.meteokav.gr/weather/
In cloud-base.php the changes I made are these:
Quote
$Settings    = './weather/Settings.php';       // optional ...not required
$WXtags      = './weather/testtags.php';       // optional ...not required (overridden if specified in Settings.php)
// WD SETUP ONLY ... The below will be overridden by Settings.php if it's available
$clientraw   = './wdlive/clientraw.txt';      // relative file address for WD clientraw.txt
$clientextra = './wdlive/clientrawextra.txt'; // relative file address for WD clientrawextra.txt
   $pathToImages     = './wdlive/images/cb/';      // path to the background, cloud, windsock and scale images (with trailing slash)
   $pathToMoonImages = './wdlive/images/cb/moon/'; // path to the  moon phase images (with trailing slash)
Is there anything wrong? I have tried also to put cloud-base.php  on /weather/ and /wdlive/ and I still get the same image. It seems that the code can't "read" my clientraw files.
Thanks for any help!
Logged
Meerkat
Rainer
Weather Guru
Offline Offline
WWW
« Reply #190 on: May 12, 2009, 02:45:51 PM »
Hi John,
You ain't doing what you say you're doing ... you've got 2 dots for clientraw files:
Code:
$clientraw   = '../wdlive/clientraw.txt';      // relative file address for WD clientraw.txt
$clientextra = '../wdlive/clientrawextra.txt'; // relative file address for WD clientrawextra.txt
You need to change to ONE dot i.e. './wdlive/clientraw.txt'
The way you've got it it's looking for the files below the root.
Logged
Cheers,
Rainer
Bashy
Guest
« Reply #191 on: May 12, 2009, 03:39:10 PM »
Hi Meerkat
Heres one for you, just noticed my wind direction not quite playing ball
It looks like it thinks O is East, please see the image below
Logged
JohnZ
Junior Watcher
Offline Offline
WWW
« Reply #192 on: May 12, 2009, 03:44:58 PM »
Hello again.
Well I have tried it even with one dot and without any dots too, and the result is the same :/ Strange?
The path for the images is working ok, and I have it like
Quote
but the path for the clientraw file is "dead".
Maybe I have to change Permissions on folders or ? I am confused.
Thanks again.
Logged
Zalmor
Weather Guru
Offline Offline
WWW
« Reply #193 on: May 12, 2009, 04:01:10 PM »
I believe the last O is actually a zero (for rain) coming from your ajaxWDwx.js file.  Line containing 'param =', I think  d'oh!
Logged
Michael A
Bashy
Guest
« Reply #194 on: May 12, 2009, 04:16:29 PM »
Are you sure? it should be saying ENE not ONO
Logged
  Print  |  « previous  |  next »  |  Go Up
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.11 | SMF © 2006-2009, Simple Machines LLC Valid XHTML 1.0! Valid CSS!
