Author Topic: Cloud Height Graphic v2.1  (Read 76967 times)
Offline Meerkat
  • Rainer
  • WD v10.37Q b31, Win 7, HP 2 Core 4GB, 72hr UPS
  • Pretoria, South Africa
    • Bashewa
Re: Cloud Height Graphic (released)
« Reply #180 on: May 08, 2009, 02:45:10 PM »
Do you ever get that feeling where you wish you never started something?  :oops:
Yeah, especially when you wanted something to be perfect and then
it turns out that there are different stokes for different folks.
Cheers,
Rainer
Meerkat's Script Collection
Script download links always available on the first page of my threads
Bashy
  • Guest
« Reply #181 on: May 08, 2009, 02:58:17 PM »
Yeah, i know what you mean, I made some new wind rose graphics that took ages to get
right for what i wanted then  before i knew it i had PMs and posts asking to change them
to suit there sites and so on... i didnt mind so much but i didnt really know what i was doing
so it took a lot longer than it would with someone whos savvy with graphics...
Still, its a great script that Rainers made and has supported it well, I just switched on
the seasons, i love the images and im very grateful...
I remember seeing something similar that someone had made loads of header images to suit
his current weather conditions, loads of images were used.... :)
« Last Edit: May 08, 2009, 06:51:11 PM by Bashy »
Offline Zalmor
  • Erin, NY
    • Zalmors' corner of the Web
« Reply #182 on: May 08, 2009, 03:54:56 PM »
Slight problem here when trying http://southerin-ny.org/cloud-base.php?uom=E&html=1&test=3 or http://southerin-ny.org/cloud-base.php?uom=E&html=0&test=3
Shows:
Code: [Select]
Warning: imagealphablending(): supplied argument is not a valid Image resource in /virtual/users/e14016-14028/web/cloud-base.php on line 839
Warning: imagesavealpha(): supplied argument is not a valid Image resource in /virtual/users/e14016-14028/web/cloud-base.php on line 840
All the other tests 1,2,4,5 work correctly.  #-o
Using version 1.9, unless I botched up something here once again.
Michael A
Windows XP Pro SP3, Pentium D 2.80GHz 3GB RAM, Quickcam Pro 4000, and APC
abaldish
  • Guest
« Reply #183 on: May 08, 2009, 04:08:32 PM »
Thanks Meerkat that fixed it.
Offline Meerkat
  • Rainer
    • Bashewa
« Reply #184 on: May 08, 2009, 07:58:52 PM »
Shows:
Code: [Select]
Hi Zalmor,
Sorry botched up again ... was a copy and paste problem from windsock code to moon code without the necessary changes made.
It only happens when you're not displaying the windsock
Grab the update below.
Last edit: Also fixed overflow of cloud height text into conditions when cloud is very low or it's misty.
« Last Edit: May 08, 2009, 11:58:43 PM by Meerkat »
Cheers,
Rainer
Offline Zalmor
  • Erin, NY
« Reply #185 on: May 09, 2009, 03:06:01 AM »
That did it, thanks  :D
Michael A
Offline Meerkat
  • Rainer
    • Bashewa
Re: Cloud Height Graphic (OZZ METARs)
« Reply #186 on: May 09, 2009, 06:54:18 PM »
There have been a couple of problems with
the OZZ METARs which I have corrected.
I've also made the changes to the METAR DECODER
which will report the OZZ METARs correctly.
Last edit: Updated yet again ... found another bug ... grab below.
« Last Edit: May 09, 2009, 11:15:50 PM by Meerkat »
Cheers,
Rainer
Offline vk2him
  • Gerringong, NSW, Australia
    • The Shack by the Beach
« Reply #187 on: May 09, 2009, 09:36:33 PM »
The new code is working great Rainer, many thanks!!
Ian
Offline Meerkat
  • Rainer
    • Bashewa
« Reply #188 on: May 09, 2009, 10:46:28 PM »
Ian
Sorry, found another bug in the OZZ METARs.
Cheers,
Rainer
Offline JohnZ
  • Greece, Kavala
    • Kavala's Weather Page
« Reply #189 on: May 12, 2009, 11:25:14 AM »
Hello guys, and congratulations for your great work here :)
Unfortunately, I can't make this script to work :( I have tried almost any possible way but the result I get always is this:
http://www.meteokav.gr/cloud-base.php
clientraw files are here
http://www.meteokav.gr/wdlive/clientraw.txt
http://www.meteokav.gr/wdlive/clientrawextra.txt
Weather Station with Ajax Script here
http://www.meteokav.gr/weather/
In cloud-base.php the changes I made are these:
Quote
$Settings    = './weather/Settings.php';       // optional ...not required
$WXtags      = './weather/testtags.php';       // optional ...not required (overridden if specified in Settings.php)
// WD SETUP ONLY ... The below will be overridden by Settings.php if it's available
$clientraw   = './wdlive/clientraw.txt';      // relative file address for WD clientraw.txt
$clientextra = './wdlive/clientrawextra.txt'; // relative file address for WD clientrawextra.txt
   $pathToImages     = './wdlive/images/cb/';      // path to the background, cloud, windsock and scale images (with trailing slash)
   $pathToMoonImages = './wdlive/images/cb/moon/'; // path to the  moon phase images (with trailing slash)
Is there anything wrong? I have tried also to put cloud-base.php  on /weather/ and /wdlive/ and I still get the same image. It seems that the code can't "read" my clientraw files.
Thanks for any help!
Offline Meerkat
  • Rainer
    • Bashewa
« Reply #190 on: May 12, 2009, 02:45:51 PM »
Hi John,
You ain't doing what you say you're doing ... you've got 2 dots for clientraw files:
Code: [Select]
$clientraw   = '../wdlive/clientraw.txt';      // relative file address for WD clientraw.txt
$clientextra = '../wdlive/clientrawextra.txt'; // relative file address for WD clientrawextra.txt
You need to change to ONE dot i.e. './wdlive/clientraw.txt'
The way you've got it it's looking for the files below the root.
Cheers,
Rainer
Bashy
  • Guest
« Reply #191 on: May 12, 2009, 03:39:10 PM »
Hi Meerkat
Heres one for you, just noticed my wind direction not quite playing ball
It looks like it thinks O is East, please see the image below
Offline JohnZ
  • Greece, Kavala
« Reply #192 on: May 12, 2009, 03:44:58 PM »
Hello again.
Well I have tried it even with one dot and without any dots too, and the result is the same :/ Strange?
The path for the images is working ok, and I have it like
Quote
but the path for the clientraw file is "dead".
Maybe I have to change Permissions on folders or ? I am confused.
Thanks again.
Offline Zalmor
  • Erin, NY
« Reply #193 on: May 12, 2009, 04:01:10 PM »
I believe the last O is actually a zero (for rain) coming from your ajaxWDwx.js file.  Line containing 'param =', I think  #-o
Michael A
Bashy
  • Guest
« Reply #194 on: May 12, 2009, 04:16:29 PM »
Are you sure? it should be saying ENE not ONO
