Thanks neighbor, my bad! Removed the comma that produced the error. Now more errors!
http://www.ardmoreweatherlive.com/wxraindetail.php
It is assumed that you are using the WD-AJAX-PHP-USA template files... right?You don't appear to be using that template.
If you were and have a typical setup, just placing the 2 files contained in the zip file without
ANY changes will result in output when you run the script without errors.
If your station is new, it won't show any data since the default values are for 2009 "still", but it won't give you any errors.
After you have that working without errors, you can then change the setting values from the defaults to get the data you want.
But if you are not using
WD-AJAX-PHP-USA template, this "addon" script won't work for you.
