Problem:
Sometimes location pins are not in their proper locations or even in the ocean.
This is a known weakness of the current geolocation technology.
Here is an explanation that might make sense for the geolocation inaccuracy issue:
Sometimes geolocation is close to perfect, sometimes not. Usually only about 85% accuracy.
The lat & lon, city, state parameters the database produces is for the location the ISP has reported for your current IP address.
Many ISPs share one block, or several blocks, of IP addresses with all their users.
Each time you connect you may get a different IP address assignment with different location details.
So the accuracy can even vary according to your current IP assignment.
This can cause the reported city, state, lat & lon from the IP to vary from your actual location.
To check the database itself, compare with this online demo.
http://www.maxmind.com/app/locate_ip
