I've just started using this script and I've run into a wee problem.
I can't get the worldmap to show on the page, or on it's own for that matter, neither will the ip addresses or flags show in the script.
What I've done so far:
Changed the settings and uploaded all the required files for the main Who's Online page to work.
The GeoLiteCity.dat has downloaded ok using wo-update.php and showed my IP address once finished. It's also set to chmod 0644 on the server and is in the root directory.
All the other required files have been uploaded to the root directory and the settings change in the include-whos-online-settings.php file.
All the database tables were set up using phpMyAdmin and they are working fine.
When I go to my who's online page (
http://www.hebwx.co.uk/whos-online.php) I get "Host: (n/a) n/a" and the "get_whos_online_worldmap error: whos online location_plugin not enabled or installed" warning. This says to me that something is missing or not set correctly.
I've seen in the readme that it says "NOTE: This script requires a mysql database to hold the ip-to-country lookup database." under the Requirements. Could this be the problem and if so, how can I get hold of the database to add to mysql or where should I be looking for it to see if it's there already?
One thing I wasn't sure about with the location plugin is whether there are any more files that I need, other then the one's that come with the Who's Online zip file and GeoLiteCity.dat?
Just for reference, I'm using the latest download of the script, v2.25 and my PHP version is 5.2.0-8+etch16.
Cheers for any help.
Martin.
