cloudy
Author Topic: Who's Online PHP Script 2.0 for your template site  (Read 110227 times)
Offline Billw69
  • If you work hard, you will have time to play hard.
  • Evansville, IN U.S.A.
    • Evansville-Weather
Re: Whos Online Script 2.0
« Reply #105 on: January 04, 2009, 10:35:01 PM »
If you view the source of the whos-online.php it shows the version.
Yours and Chucks are version 1.52
<!-- Version: 1.52 - 31-Dec-2008 - Who's Online PHP Script by Mike Challis -->
The latest version is 2.00 released today 02-Dec-2009
Should I try to update to version 2.1 yet? Or will there be more great improvements to this wonderful script?
Offline MCHALLIS
  • Long Beach, WA USA
    • Weather for Long Beach, WA USA
Re: Whos Online PHP Script 2.0 for your template site
« Reply #106 on: January 04, 2009, 10:46:44 PM »
Billw69 go for it.
I am now trying to freeze the features for awhile.
Offline K3JAE
  • Fayette County, PA., USA
    • K3JAE's Weather Station
« Reply #107 on: January 04, 2009, 11:14:43 PM »
Mike;
Thank you.  Problem resolved and works.  :)
I had the right idea as was working towards that resolution but screwed up the #page id evidently.  Now I can rest and find another problem to tackle....
~heads off to Linux box to see if maybe can get WD to work there right.... ~
73's de K3JAE
John
K3JAE Weather Station
Offline Billw69
« Reply #108 on: January 04, 2009, 11:29:02 PM »
HMMMM. After downloading the zip and reading the upgrade instructions, I think that I will wait for Tims assistance. I don't know anything about SQL. I sure don't want to break what he has working. It is working OK for the time being.
Offline n9mfk9
  • Springfield IL, USA
« Reply #109 on: January 04, 2009, 11:52:42 PM »
hi Mike two questions
how do i fix this error
http://www.n9mfk.com/mwwn/
this is in its own dir
also whats  best site for ip look up
my ip not in the default thanks beau
Offline MCHALLIS
« Reply #110 on: January 05, 2009, 12:00:43 AM »
You cannot use the worldmap unless you install and enable the "location-plugin"
Read the readme.txt in the location-plugin folder
There are a few sample ip lookup sites listed in include-whos-online-settings.php
You can try and decide what you like or find more online.
Code: [Select]
// http://www.showmyip.com/?ip=
// http://www.geo-location.com/cgi-bin/index.cgi?s=
$C['whois_url'] = 'http://www.geo-location.com/cgi-bin/index.cgi?s=';
Offline mth
  • Baltimore, Maryland
    • Relay, Maryland Weather Source
« Reply #111 on: January 05, 2009, 12:02:09 AM »
Hi Mike,
I'm looking to breakdown the <?php echo $whos_online_records; ?> to something a little less "bulky".  Right now, this takes a lot of space on the footer, so I'm currently not including it.  Is there a way to break these apart for individual use?
4 Visitors online right now
Max visitors today: 9 at 12:06 pm EST
This month: 9 at 01-04-2009 12:06 pm EST
This year: 9 at 01-04-2009 12:06 pm EST
All time: 9 at 01-04-2009 12:06 pm EST
Michael
Michael Holden
Relay, Maryland Weather Station
http://www.relayweather.com
Offline n9mfk9
« Reply #112 on: January 05, 2009, 01:01:10 AM »
hi Mike, is there a way to set it up with out a 29 mag file in the sub folder
beau
Offline MCHALLIS
« Reply #113 on: January 05, 2009, 01:34:53 AM »
Hi Mike,
Michael
OK
Version: 2.02 - 03-Jan-2009
- renamed function get_whose_online_worldmap to get_whos_online_worldmap
- added print array for individual records display
You can still add all the stats to your template footer section like this (or anywhere on your site you want it)
Code: [Select]
<?php echo $whos_online_records?>
(new) you can show the stats one at time like this:
Code: [Select]
<?php echo $wo_record_array['now']; ?>
<?php echo $wo_record_array['today']; ?>
<?php echo $wo_record_array['month']; ?>
<?php echo $wo_record_array['year']; ?>
<?php echo $wo_record_array['all']; ?>
to upgrade from 2.01, replace include-whos-online-header.php
Offline MCHALLIS
« Reply #114 on: January 05, 2009, 01:38:05 AM »
beau
Yes when the location plugin is disabled with this setting:
$C['enable_location_plugin'] = 0;
The GeoLiteCity.dat file is required when you enable the location plugin because that is where the location data comes from.
lat & lon, city, state and country.
Offline mth
« Reply #115 on: January 05, 2009, 02:35:19 AM »
Hi Mike,
2.02 up and running with the individuals in my footer!  Appreciation as always! :)
Michael
Michael Holden
Offline jmcmurry
  • Jim McMurry
  • Mauston, WI, USA
    • Juneau County Weather
« Reply #116 on: January 05, 2009, 12:17:16 PM »
For those of you who were into this project early when Mike introduced the GeoLiteCity.dat data from maxmind.com, there's a new set of data updated 1/1/09.
Just to let you all know, they really do update the free version.  In the December copy I showed up as Sun Prairie, WI about 60 miles away and now I show up as Adams, WI which is only about 10 miles from home.  The lat/long of course changed too.
I wonder, could a script download the .gz file straight to the server and uncompress it there?   I suppose not worth the coding effort and there'd probably be problems with different versions of PHP.
- Jim
 Home of NSLog NexStorm Lightning Data Manager
Offline pinto
  • Belgium
    • weather station Kampenhout
« Reply #117 on: January 05, 2009, 12:48:10 PM »
Quote
http://www.maxmind.com/app/installation?city=1
use cron, day 10 seems to be a good day
write bash-script when on Linux and follow the directions on the page in the link(only 3 lines)
for people who do know what it's all about
if you don't, download the file, unzip it and do the upload to your server
Offline mth
« Reply #118 on: January 05, 2009, 01:41:47 PM »
Concerning the problem with the map pin locations:
On Firefox 3, my pins are dead on the location
On IE 7, the pins are about 600 miles south of there respective locations.
So, it seems to be a browser issue.....
Michael
Michael Holden
Offline n9mfk9
« Reply #119 on: January 05, 2009, 02:36:01 PM »
Hi Mike i have it running on my main part of my site but not in the sub folder
thanks Beau
