New Station Honeywell TE831W-2
Santa brought this, there are 3 temp sensors, is there a configure option to add the third?
Also, what linux device node is WD communicating with, it does not give that info in the data window. I can run as root fine, but I have a mixed debian system, so my udev is not the most current, and the rules to run as non root do not seem to apply.
OK, bit better search, and I have my answer in this thread on the usb node
WH1080/1081 registers as hiddev# and will not connect
