New to running Linux (that’s alot of my problem). Setting up a wmr-100 on a mini-itx box using Damn Small Linux (2.4.31). My hope is to have this little box sit here and log/sever data to my MrHouse machine. But, I can’t seem to even get the display software to run:(
Installed to /Weather/ with directorys at /Weather/wdisplay and /Weather/deploy
I’m new to WD, too, but I think you’re getting the path error because you don’t have your Deploy directory under your /Weather/wdisplay directory. Did you move your Deploy directory after installing?
Here is what I did. This assumes you are using X windows with either Gnome or KDE (other window managers will work.) If you are not using X windows then you want to Weather Display For Linux Console.
Download the appropriate tar.gz file. In this case I use WD-Gtk. Make sure you have the most recent LibC and Gtk installed.
This is donationware (free to use). Requires GTK1 installed and a recent LibC
Version on 3 December 2008 - 00:20:26 32.45 MB
Once downloaded, in the home directory of the user do a tar xzvf WeatherD.tar.gz
This will create the wdisplay directory and the appropriate sub-directories. You should not move files around.
cd wdisplay
./GoWeather.sh
If you want to log the STDOUT you can startup by doing the following:
./GoWeather.sh >WDout.log 2>&1 &
You can then more or tail this file. I use ‘tail -f WDout.log’ so I can monitor the log file.
Once WD is started you need to configure the connection by using the ‘Control Panel’. Also, the wiki has good directions for setup.
