cloudy
Author Topic: WDconsole - Version 5.1  (Read 1888 times)
Offline ve2ymm
  • Montreal, Qc - CANADA
    • www.YvesMartin.net/meteo
« on: October 29, 2008, 02:04:13 AM »
I'm using last version 5.1. This is what I have :
- Icon and Sun/Moon rise information show strange information.
- Icon say time is dry and clear (it is raining and sometime snowing). MesoMap show this info too.
- Values on Sun/Moon has no sens (see picture)
- Fire index is "Extreme" (?) has no sens too (see picture)
« Last Edit: October 29, 2008, 02:11:51 AM by ve2ymm »
YM
Montreal, Qc (CANADA) : http://www.YvesMartin.net/meteo
Re: WDconsole - Version 5.1
« Reply #1 on: October 29, 2008, 02:11:01 AM »
to find out what is wrong with the clientraw files, you will need to use the online parser
most likely there is an extra space somewhere occuring, probably with the weather description
in fact, if you have wind and rain, the the weather description will be Windy Rain
in the client raw file
it will be that extra space that will be the problem
I will change it to Windy_Rain instead
also note that the consolewd does not calculate FWI, so do not display that on your WDL
« Last Edit: October 29, 2008, 02:13:36 AM by windy »
Offline ve2ymm
« Reply #2 on: October 29, 2008, 02:14:37 AM »
In the parser I have :
048   Icon Type   Z   1 (Clear Night)
049   Weather Desc   L   Dry/Night time
Now it is snowing here ;-)
YM
« Reply #3 on: October 29, 2008, 02:17:52 AM »
in checking your data with the online parser
I see the problem
its the forecast string from the davis VP
I have not replaced the spaces with _
will fix that now and upload vers 5.2
« Reply #4 on: October 29, 2008, 02:25:13 AM »
done that now
re snow....has the station recorded rain (and has consolewd recorded rain?)
Offline ve2ymm
« Reply #5 on: October 29, 2008, 02:56:20 AM »
done that now
yes but values are differents. Hard console recorded 20.4mm., WDL show 9.6mm (?). Hard console show Snow (little star icon for freezing I thing) but WDL show dry weather and clear night...
Do you know how Davis VP2 record snow?
YM
« Reply #6 on: October 29, 2008, 04:20:36 AM »
note that wd keeps its rain total separate from the console
what I mean is that have you recorded recent rain?
also note that the forecast icon from the VP is not working in the consolewd version
(but I could get it to flow through to the forecast icon number)
Offline ve2ymm
« Reply #7 on: October 29, 2008, 10:59:47 AM »
... about rain I understand. WDconsole lost data when I update to 5.0 and 5.1. After I get com lib from old version, it was restarting...
I know forecast icon and text are not working on Davis VP, but icon for actual weather is not working too.
What about wrong values on Sun/Moon. This was working before on version 3.8, even if value was different from my GPS.
YM
Offline n7dq
  • Windsor, CO
    • Windsor, CO - Weather -- N7DQ
« Reply #8 on: October 29, 2008, 12:49:43 PM »
By old version of the com lib will the one work from wdconsole 4.8?  I have tried 5.1 with Davis VP2 and get no data.
Mike - N7DQ
Mike - N7DQ
http://www.n7dq.com/weather
CWOP: AT059
WeatherUnderground: KCOWINDS8
Offline ve2ymm
« Reply #9 on: October 29, 2008, 01:49:59 PM »
Mike - N7DQ
Actually, I use 5.1 with libcom.so (Jun 28 01:03 34369 bytes), provided with version 3.0. Version with 5.x do not works for me.
Yves - ve2ymm
YM
Offline n7dq
  • Windsor, CO
« Reply #10 on: October 29, 2008, 02:46:47 PM »
I was able to use the libcom.so from the 4.8 version to get wdconsole to work also. It seems to be feeding data to wunderground, mysql and CWOP just fine.
Mike - N7DQ
Mike - N7DQ
CWOP: AT059
Offline ve2ymm
« Reply #11 on: October 29, 2008, 03:37:00 PM »
Mike - N7DQ
yes, my problem was with WDL... updates was not functional, no idea why.
Mysql and CWOP was working just fine.
YM
« Reply #12 on: October 29, 2008, 04:22:55 PM »
sun and moon info should be working OK
does for me here in testing
now, re the davis VP and the latest libcom.so
is this with a revb type data logger?
Offline pablo
« Reply #13 on: October 29, 2008, 04:43:54 PM »
I see you bundled in 5.2 the fix for the problems I reported (column 15 and 48).  Thanks.
Unfortunately there seems to be a regression on the %moonage% tag.  It now has a blank space at the end.  For today, it's  `1 ' ... whereas it used to be `1'
pablo
WMR-100
Offline pablo
« Reply #14 on: November 07, 2008, 09:47:47 AM »
bump
pablo
WMR-100
