Inconsistency detected by ld.so: dl-minimal.c: 148: realloc: Assertion `ptr == alloc_last_block' failed!
Hi, I have also the same problem. Short history: I ran Ubuntu 8.04 with WD console without any problems for two months. At some point (timing is bit unclear, I just can't remember), I installed minidlna for pushing data to my TV via ethernet. Installing the software required a huge amount of packages to be installed before I could compile and run it (list of packages can be found somewhere if needed). After that the "Assertion failed" problem came up.
I didn't use too much time to fix the problem, but I installed Ubuntu 8.10 and everything started to work again (at this time with WD console version from March 10, 2009). Today, after running WD console roughly one month on the new installation, I installed MythTV on the same host to get DLNA working again. I needed a reboot because I screwed up with group update (removed myself from the admin group
, and after the reboot, the assertion failed problem occurred again.
The packages that were installed with mythtv are listed here:
http://jokela.org/misc/installed_110409.txt. Any idea what is going wrong, and where? The problem seems to relate to some package that is installed with these sound/video/graphics softwares.
EDIT: And my weather station is Oregon Scientific WMR100.
/Petri
