cloudy
Author Topic: WMR918 extra sensor 3 - details dissappeared  (Read 1416 times)
Offline Westisbest
  • Weather - because there's lots of it
  • Sun Spot Cycle
  • Ireland
« on: September 24, 2008, 10:52:02 AM »
Version - 10.37L build 16
Station - WMR968NX
OS - XP SP 2
Problem - Sensor 3 details - name, high, low dissappeared after build 1 10.37L on viewing extra sensors page
Regards
West is best
Cheers
WestisBest
_____________________________________________
Cold, wet & miserable.... and now for the weather!
Online Weather Display
Re: WMR918 extra sensor 3 - details dissappeared
« Reply #1 on: September 24, 2008, 07:00:22 PM »
can you post a screen shot so I can see exactly what you are refering to and seeing?
thanks
Offline Westisbest
  • Sun Spot Cycle
  • Ireland
« Reply #2 on: September 25, 2008, 12:27:29 PM »
Here is a print screen
Regards
Westisbest
Cheers
WestisBest
Offline Westisbest
  • Sun Spot Cycle
  • Ireland
« Reply #3 on: September 25, 2008, 12:46:51 PM »
Sorry.
Meant to include the same print screen from build 1.  (the one above is from build 16)
Regards
Westis best
Cheers
WestisBest
« Reply #4 on: September 25, 2008, 06:02:35 PM »
is it a temperature only sensor (i.e no humidity) by any chance?
i.e does a current humidity show at any stage?
Offline Westisbest
  • Sun Spot Cycle
  • Ireland
« Reply #5 on: September 25, 2008, 07:07:14 PM »
No Brian,
Its a Temp/Hum sensor (one of three)  All three have worked fine over the years in different WD versions, all showing temp & hum current and High / Low for the day.  Strange thing about this error is that even the name of the actual sensor dissappeared.  If I copy back in build 1 of 10.37L, its fine.  Copy in current version and error is there
All three battery levels are 100% also.  Hope this helps
Regards
Westisbest
Cheers
WestisBest
« Reply #6 on: September 25, 2008, 07:48:29 PM »
my bad
problem happened when I added ability to show extra temp/hum from #4 or above for a OS WMR100/200 station
use a new .zip update, ready now
Offline Westisbest
  • Sun Spot Cycle
  • Ireland
« Reply #7 on: September 29, 2008, 09:52:48 AM »
Hi Brian
Tried build 17 - same problem still exists.  Label name is still missing, high and low data fields still blank
Any ideas?
Regards
Westisbest
Cheers
WestisBest
Offline SandhurstWX
  • Ian
  • Another satisfied WD user!
  • Royal County of Berkshire, UK
    • Sandhurst Weather
« Reply #8 on: October 02, 2008, 08:02:43 AM »
I up-dated to v10.37L build 18 last night, and in the high & low boxes for Extra Sensor 3, the data is being displayed in scientific notation (see attached shot). The value for High reads 8.50000000000000E+001% and the Low value is 7.70000000000000E+001% (85% & 77% respectively).
Also, clicking on RESET had no result.
Cheers,
Ian
geoffp0
  • Guest
« Reply #9 on: October 02, 2008, 08:46:12 AM »
Hi Ian,
I have exactly the same problem as you there, also on the graph for that sensor the temperature scale is showing from minus 90 to minus 99 degrees ????????
Geoff :(
« Reply #10 on: October 02, 2008, 05:24:07 PM »
should be all fixed up in build 19 .zip update, ready now
Offline SandhurstWX
  • Ian
    • Sandhurst Weather
« Reply #11 on: October 02, 2008, 05:57:26 PM »
Just installed and now working OK! Cheers Brian.
Ian
Offline Westisbest
  • Sun Spot Cycle
  • Ireland
« Reply #12 on: October 03, 2008, 12:30:30 PM »
Still a minor problem with WMR918 extra sensor 3.  If you put in a name using the "set sensor name" option... it defaults back to "Sensor #3"?
Any ideas?
Cheers
WestisBest
geoffp0
  • Guest
« Reply #13 on: October 03, 2008, 02:04:45 PM »
Yep, I have the same problem.
Geoff
« Reply #14 on: October 03, 2008, 06:24:08 PM »
